Jim's Pole Barn Project - hopefully
   / Jim's Pole Barn Project - hopefully
Re: Jim\'s Pole Barn Project - hopefully
From the left front.
From the left side.
   / Jim's Pole Barn Project - hopefully #43
Jim, I would leave any bracing that you can. Unless it is in the way of putting up your horizontal boards I would leave it.
Spence
   / Jim's Pole Barn Project - hopefully #44
I've seen that contractors don't put the cement in the pole holes until they have a good part of the frame built. They just leave the bracing up. I guess this gives them a little nudges if the poles are a little off.
What do you all think about that? Most telephone poles aren't perfectly straight and it might be a good thing to have them a little loose to square them up?
gary
   / Jim's Pole Barn Project - hopefully #45
Jim ,
Leave the bracing on until you've got the trusses and decking in place . In fact , if you can add longer braces to the poles . You'll be adding girts and headers to those poles and it tends to move them A LOT ! After you get your girts and headers on , run a string along the header at 1-1 1/2 " . reset the poles as required . then install the trusses . After the trusses are set , recheck the line .( putting braces from the bootom chord of the truss to the base of each pole also helps lock things together ) Also, before you deck it pull a diagonal measurement from peak to gable end (truss tails )
both ways . I know it sounds overly complicated . But you get a square and plumb building . Also check the corner poles for plumb,and brace them diagonally after the girts and heaqders are in place . All the best , John
   / Jim's Pole Barn Project - hopefully #46
If you want to increase the life of your poles, don't use concrete at all. Put a foot on the bottom of your pole to keep the wind from pulling it out, and just tamper in soil, or rock and soil.
   / Jim's Pole Barn Project - hopefully #47
Jim , not many folks concrete their poles in . One reason is as you mentioned ... you may need to true the poles . The other is that if you pour a concrete slab it'll lock the poles together as if you'd poured the holes . As was mentioned before ... nailing anti lift blocks on the poles would be nice . But, as you've set your poles ..... a bit of rebar drilled into the poles below finish level in the concrete will work fine . John
   / Jim's Pole Barn Project - hopefully #48
Jim,
Looks like you're making great progress
Jerry
   / Jim's Pole Barn Project - hopefully #49
Things must be a little more relaxed there as far as the permit process. Where I live, the building would not get through the engineering review stage if the poles were not cemented. The cement not only prevents the building from being lifted - it also provides shear strength.
Not much progress, but I have gotten the rest of the poles up on the "left" side.
2016 Gooseneck 32' Livestock Trailer (A50121)
2016 Gooseneck 32'...
377669 (A51573)
377669 (A51573)
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
