Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #41
There is a lot of debate on the best direction or way to go up a hill. I mow some 30 degree slopes and go both forward and others I back up. Really for me it depends on what is at the top and do I have room to turn around. One place we have a bldg. at the top so I back up that slope so the mower can get close to the building. I leave my loader on so that adds a little weight to the front which doesn't hurt. The MX does well on hills and going up and down has never been an issue. I ALWAYS lose traction before having any concerns about flipping.
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #42
It matters little, except be sure to use 4WD, especially when the front is downhill.
Most, if not all tire manufacturers have extensive dimensional data online for all current offerings.
Thanks for the tip. Yes indeed they did. The results show the provided R4 rear tire is notably shorter than the R1, and would lower the rear of the tractor about 1-5/8". Not a world of difference but maybe something to factor in the decision.
Actually now I note the "static loaded radius" which is probably more relevant. This would indicate a lowering of only 1.15"
The R4 sidewall is presumably a bit stiffer?
Gustave
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #45
Usually R4 tires are considered to be stiffer than R1 tires. Usually R4 tires are 6-ply and R1 tires are 4-ply, with R1 flexibility consifdered to add to traction.
UNUSUALLY the R1 tires in your chart are 10-ply, while the R4 tires are the usual 6-ply. So UNUSUALLY the R1 tires in your chart probably have sidewalls stiffer than the R4 tires in your chart.
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #46
To compare the track width of R1s and R4s you'll have to measure the actual setup you're considering, with the wheels set up as you wish if they're adjustable. Manufacturers don't provide enough information there. Usually what they list is for R1s only. Many tractors have adjustable wheels both for R1s and R4s.
Shorter tires will lower the center of gravity making the tractor more stable on hills. It will also reduce the ground clearance of course. I had slightly smaller R4s put on my Branson, with spacers on the non adjustable rears, for stability. I have not been bothered by the reduction in ground clearance but I try to be aware of what I'm driving over.
When going up very steep slopes I back up in 4wd, keeping the loader low. It would take an extremely steep slope to get a tractor to go over that way though.
I see what you are saying Jeff. I did notice more than one 26" R1 tire listed on the Titan website, but was not sure what the difference was. So i just picked the first one. Now, looking more carefully, I see that the second two types both seem to be 6-ply. I do not see any 4-ply R1 tires in this size and type on their website. All three 26" R1 tire types have the same listed static loaded radius. But in line with your comment, the 10-ply tire, with a 32% higher rated load should be stiffer, and therefore deflect less under load. So I'm not sure how much stock to put in these numbers.
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #49
Lower ply tires deflect a similar amount at rated load as higher ply tires because as plies decrease so does the rated load. Therefore loaded radius remains the same. These are manufacturers numbers, you can trust them more than the average keyboard jockeys pontification.
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #50
What is the price for the Kabota MX4800 w4x4 in your area
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #51
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #52
I致e been to the website just wondering how accurate their website is to the dealers actual price
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #53
Pricing varies by region. Lowest prices in the south, where tractors are imported and ag is important.
Highest in California and NE.
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #54
That tractor won’t pop walnut stumps and I wouldn’t bother grading with it unless you’re experienced with a box blade with a hydraulic top link and that would only be finish grading... very light stuff. My 2 cents as owning an excavating business
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #55
We have owned (among other tractors) a Kubota M5400 with R1 tires, a Kubota L3800 with R4 tires and our current MX5800 with R4 tires, all with the rear tires loaded. The two larger tractors had their rear wheels set in the widest position and are IMO much more stable than the L3800, even after we put 4" spacers on each rear wheel of the L3800, although the spacers made a big difference. One footnote, though, is that with the rear wheels set as wide as possible, the M5400 was and the MX5800 is too wide to fit between the fenders on a trailer with a 78" deck but will fit on an 82" deck.
I have not yet checked. I'll respond when I get a quote.
Gustave
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #57
I up dated my profile ,it's Kevil Kentucky 42053 area
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #58
I’ve e been looking at the exact same tractors and have the same stuff to do plus moving hay bales because Im putting cows on our pasture. I love the l3901 price but its not big enough for this stuff. The l4701 is cool but its an oddball and probably wont be around long. The MX is a workhorse and I think thats the way to go. Maybe a Grand L too. Pretty similarly priced for like an L4060.
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #59
Was Evil Knievel ever in Kevil? :D
Kentucky is a nice place :thumbsup:
/ Kubota L3901, L4701 or MX4800 for Sloped 10 Acre Parcel and Home Build #60
I’d go with the MX5200 because of the turbo ;). Get 3 rear remotes one with float detent. Get the 3rd function on the loader. Top N tilt cylinders for the 3pt. Get a nice heavy duty Gearmore box blade, with hydraulic rippers. A hydraulic auger would be nice to have for your fencing chores.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A60429)
2014 GENIE...
2003 Big Tex 10PI...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
2025 CATERPILLAR 255 SKID STEER (A60429)
2025 CATERPILLAR...
10222 (A56858)
10222 (A56858)
