L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints
Unless you are just dead set on having the integrated valve system, you can get better valves for less money going after market. About a $1000 less. :cool:
I have nothing against a budget system, since it gets the job done -- so if you can get by with $100 valves to go along with $150 cylinders, it could all be done for about $600-700 with hoses, fittings, etc. It won't look like much and the integration might be crude, but it's a great value.
I think where things go astray is spending more than that for a semi-packaged aftermarket system that still doesn't integrate well with the tractor. I don't see the point. Once you start getting up past $1000 for valves, my recommendation is to just spend the money for the nicely integrated OEM valve kit for this tractor, as I haven't really seen an aftermarket or homemade system for these tractors that didn't look kludgey and still take fiddling to get right. The OEM kit has great integration/ergonomics and is high quality, and that type of design/fab is not easily done by other folks. I spent $1300 for the OEM kit with two valves (one float/detent), rear outlets, fittings, etc.
And then make up your savings by doing the hydraulic cylinders and hoses yourself because that is pretty easy to do. I spent less than $150 for my top link with custom hoses, fittings, etc. Side link would cost me even less. So all in I would be at about $1600 for the valves and cylinders, in the ballpark of aftermarket kits (and actually less than some I have seen). Look at the big picture when thinking about the budget and put the money where it is best spent.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #22
After looking, it appears that it may be best to just run a towable splitter. So a good combination would be
1. Valve with float for top link
2. Valve with float for side link
3. This one I'm still open about but think a normal DA one either with a detent or provision it to stay on by a bungee or barrel lock/latch.
I came to the same conclusion about a towable splitter, mainly because I didn't want to tie the tractor down -- it needs to be available to bring logs and wood to the splitting site.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #24
I am very surprised that a true TLB has this type of valve. :( Thank you for clearing this up and admitting that on the regen side it is slow and has basically no power. There have been other discussions on other forums where the guys say every thing works fine, same speed, same amount of power etc. I questioned them, but to no avail. It makes no actual difference to me, I don't have those types of valves on anything.
Thanks again. :thumbsup:
In reality, I'm not surprised in the least. Other than running equipment other than a loader/bucket, what would the L45 FEL valve be used for? The 4-position loader valve found on tractors with removable loaders makes sense to me. Those loaders come off and the same valve is used to run Kubota optional snow plows and front mount blower chute controls. The FEL is permanent on the L45 so there really is nothing else the FEL valve should be used for in Kubota's mind. They offer a 3rd function kit if you want front hydraulics so that is the way they assume their commercial market would go to run augers and grapples.
Anyone telling you a regen dump circuit works with a diverter is a liar. Think about it, they simply can't be telling the truth or they are too ignorant to know any better. 1st of all, it will ONLY run DA cylinders. 2nd of all, it will ONLY run a DA cylinder in the same manner as the original curl/dump setup. If hooked up backwards it will simply not move when the regen direction is activated.
WRT to speed...it's not possible to be "fine". The regen direction is slow as mollasses. Think about it, we are relying on the minute difference in cylinder piston vs rod side geometry to make motion. No way on earth that is equally as fast as a properly running cylinder where one side is pressurized and the other goes to tank.
WRT to power...this is more subjective, but I don't feel like I have the power I should when using the regen direction. The regen direction closes my grapple. When I try to pinch something it seems to tap out before it applies the pressure I think it should be capable of. Both sides of the piston have pressure, so maybe it finds a "neutral" once the pressure relief kicks in?
Another major drawback: You simply can't run anything that isn't a DA cylinder. No hydraulic motors so no hydraulic auger.
Either way, regen + diverter = major disappointment. I'll definitely be swapping to the lift circuit come Spring.
ac
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #25
ac
First off, you don't need to explain anything to me, I understand how the regen works. I simply passed on what other people had said and thought that I had conveyed that it was most unlikely. I guess not.
So you don't use your loader for digging at all? With having only regen for the dump circuit, how do you angle the bucket into the ground? I know that on my 580 Case , we use the bucket to dig with all the time. I always thought of the Kubota TLB as little commercial machines, no? Seems like it wouild be a pain to have to always set the angle before you had the bucket on the ground, probably just something that you get use to though.
No big deal either way, I was just surprised is all. ;)
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #26
Brian,
I didn't think I had to explain anything to you. I was trying to provide enough explanation to support my experiences. Since you know so much, can you confirm my experience that the dump circuit "loses power" when you push it to pressure relief?
My machine has no trouble digging with the front bucket. It easily lifts the front of the machine with the dump circuit. The TLB IS a "little commercial machine", I'm not sure how full size machine loaders are done as I have no experience. I'm pretty sure the operators manual suggests small cuts with the bucket when digging, but that is the same advice given in my "How to Operate TLBs" book that is intended for starting professional operators. The operators manual for the L45 specs the "Digging Depth" as 3.5". I've never noticed any issue with the loader function until I installed the diverter. Lesson learned on this side and I feel like the topic isn't discussed enough on the forum so I'm trying to bring it up more to educate the masses. Even if my machine had the 4-position valve, pushing passed a detent every time using the diverter might get old to me.
I'm attaching a picture of the FEL control function for a Kubota with 3-position FEL valve. If someone has a tractor with this sticker on the loader, I strongly suggest they go 3rd function or at least prepare to use the lift function for the diverter.
ac
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #27
Not all tractors, in fact most I would say have the regen at the far right, not like the Kubota units that have regen before the normal dump. To the best of my knowledge, only Kubota and JD use the regen only dump circuit on their tractors.
Say the cylinders are 2" dia with 1 1/4" dia rods. Pump is set at 2500psi. Rod side has 4800lbs of force. Piston side has 7850lbs of force. Now go into regen and you only have 3050lbs of force. So yes you have gone from 7850 down to 3050. You have lost over 60% of the force that you would have without regen.
Yes you loose power in relief, that opens another port for the fluid to return to tank. Sort of depends on the system design and size as to just how much is lost.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #28
That seems odd they would place regen on the far right. Using a bucket, wouldn't you want regen when dumping so you don't lose control of the load dumping accidentally? Maybe I misunderstand the true purpose of the regen?
I appreciate your math. That seems to coincide with my experience.
ac
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #29
ac
I'm not sure what you mean by "losing control of the load". :confused: Either you dump the load, or you dump the load quickly. (regen at far right) If anything, to me it makes more sense to go slow, then fast vs fast then slow (Grand Ls & M models I believe?)
Not that it really makes any difference, they both work, just have to adjust if you go from one type to the other. ;)
Regen is suppose to dump faster, but to do that, the bucket needs to be loaded, the weight with the additional fluid from the rod end bumps up the GPM a bit that is flowing into the piston side (closed end) and is suppose to speed things up. For whatever reason this seems to work well on some machines and not so much with others. I believe that how ever it is that the valve is made happens to be why some seem to work better than others.
Didn't use to make much difference, but then people became aware and some what educated about this stuff. I wouldn't doubt that the manufacturers don't really like us all that much. :confused3:
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #30
Oh, I thought the purpose of the regen function was to maintain bucket control when dumping heavy loads. I don't understand how applying pressure in the opposing direction of the cylinder as well as the desired direction would result in a FASTER dump? I thought the concept was to control the dumping action even when the force of the dumping load was greater than the ability of they hydraulic system to control it. This probably wouldn't happen much on smaller machines with littler buckets and reduced loader capability.
ac
AIR TANK & HOSE REEL (A58374)
AIR TANK & HOSE...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
JOHN DEERE 9570 RX (A58214)
JOHN DEERE 9570 RX...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
