MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,156
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I've set up my AGP three times... the first initial setup, the second after moles undermined and collapsed it
and the third for the moles again.
So here's my advice...
First, be sure to remove ALL of the grass and roots. If you do not, they will rot and decay and compress and leave indentations in the bottom of your liner. Even if you add sand, the grass under the sand will rot and the sand will collapse. If there was a stump or tree roots under there at one time, find another place as they will rot and leave indentations under your pool liner.
Second, if at all possible, do NOT move soil from the high side to the low side and attempt to compact it. Instead, dig into the side of the hill and make a level pad on undisturbed soil working from the low side in towards the hill.
Third, put one 1" by 6" by 12" patio block under each upright post. It helps keep them level.
Fourth, have you considered a pad between the outer wall and liner? I did this the second time I put it up and it really makes the pool quieter and holds heat longer at night. It is only 1/8 inch thick, but really helps. Also lessens the chance of the liner getting torn on the sidewalls. Also, the cove molding that goes down around the interior edge makes a nice touch and looks and feels much nicer than a sand berm.
Fifth, put the pump as far away from the pool as practical or put it behind a fence or wall. While they are not that loud, it makes for a nicer insallation if you can't hear it that much.
To level out the sand bottom, put a stake in the middle with the desired sand depth. Use long pieces of conduit and lay them on the sand and level them to the center stake mark. Use two or three of them like wagon wheel spokes. Use a long level as a screed to level the sand between the spokes. Keep working your way around the center stake moving the spokes as you go. It really works well and goes pretty fast. Compact the sand and check for level again. By the way, it gets HOT working inside a metal ring. Make sure someone knows you are in there and they check on you often. It is like sitting inside a magnifying glass and heat exhaustion/stroke is a real danger.
Finally, most pool places have installation crews that can do the entire job in less than a day. They do it well and they do it often. They will get your liner nice and straight and will leave no wrinkles. After all the work and frustration, it is worth the couple hundred or less they will charge to put it in. If I ever get a new pool, I will pay to have it installed.
