LUBING FEL
   / LUBING FEL #21
I like to use general purpose EP grease because the FEL certainly gives grease a workout. I think even lithium grease is acceptable in my Owner's Manual, but that's one I'll have to check to make sure.
   / LUBING FEL #22
I use the New Holland grease. It's high-pressure, meets the requirements, is about as cheap as anything else, and it is <font color="blue"> blue </font> ! /forums/images/graemlins/grin.gif
Mark
   / LUBING FEL
Lithium grease is the one I use & have been told is superior to your standard grease you can buy. Not only that, it is recommended by New Holland. (Stated in my Manual) You can get lithium grease pretty much anywhere so shop around for best prices. Normally white in colour. It's more expensive but provides superior lubrication.
   / LUBING FEL
What you normally want in a grease is a lubricant that will not absorb water & has a high temperature rating so it will not break down under stress. Attached is some info I found on the net.
   / LUBING FEL
I tried putting the info all in one document but did not work. Here is some more info.
   / LUBING FEL
More Grease....more g.r.e.a.s.e. !!!!!
   / LUBING FEL
Last One.
   / LUBING FEL #29
</font><font color="blue" class="small">( and it is blue !
)</font>
I used to use New Holland grease. When I did, I only had two kinds of t-shirts. Those with blue circles on them and those that would soon have blue circles on them. AAARGH! /forums/images/graemlins/laugh.gif
   / LUBING FEL #30
Thanks for all the great replies. Looks like I will be heading to the local supply store tonight. Oh darn! I also noticed that some of the zerks are broken off...will I have to go to the NH place to find these? Anyway, thanks again, this looks like a great resource.
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
American G-Model Pump Jack (A56435)
American G-Model...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
New/Unused CFG Industrial MH12R Mini Excavator (A57453)
New/Unused CFG...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
