LUBING FEL
   / LUBING FEL #21
I like to use general purpose EP grease because the FEL certainly gives grease a workout. I think even lithium grease is acceptable in my Owner's Manual, but that's one I'll have to check to make sure.
   / LUBING FEL #22
I use the New Holland grease. It's high-pressure, meets the requirements, is about as cheap as anything else, and it is <font color="blue"> blue </font> ! /forums/images/graemlins/grin.gif
Mark
   / LUBING FEL
Lithium grease is the one I use & have been told is superior to your standard grease you can buy. Not only that, it is recommended by New Holland. (Stated in my Manual) You can get lithium grease pretty much anywhere so shop around for best prices. Normally white in colour. It's more expensive but provides superior lubrication.
   / LUBING FEL
What you normally want in a grease is a lubricant that will not absorb water & has a high temperature rating so it will not break down under stress. Attached is some info I found on the net.
   / LUBING FEL
I tried putting the info all in one document but did not work. Here is some more info.
   / LUBING FEL
More Grease....more g.r.e.a.s.e. !!!!!
   / LUBING FEL
Last One.
   / LUBING FEL #29
</font><font color="blue" class="small">( and it is blue !
)</font>
I used to use New Holland grease. When I did, I only had two kinds of t-shirts. Those with blue circles on them and those that would soon have blue circles on them. AAARGH! /forums/images/graemlins/laugh.gif
   / LUBING FEL #30
Thanks for all the great replies. Looks like I will be heading to the local supply store tonight. Oh darn! I also noticed that some of the zerks are broken off...will I have to go to the NH place to find these? Anyway, thanks again, this looks like a great resource.
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
2015 Freightliner M2 106 AWD Terex Commander 4047 Digger Derrick Truck (A55973)
2015 Freightliner...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2018 Freightliner M2 106 Medium Duty AWD Altec AA55 56ft Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
