More Power !
   / More Power ! #1
Scrambler82
Veteran Member
SoCal
Mahindra Max 28XL, HST, TLB
I was wondering, well I ws wondering about two things... !
1) Is there a way to increase the Horse Power on the Max28 ?
2) Is there a way to increase the Hydraulic Pressure on the Max28 ?
If either 1 or 2 can be done, what is the best way to achieve both !
Thx / Ltr
Just to calm the beast, I did a search and did not come up with the needed info !
Although I do remember a thread or two about the subject !
   / More Power ! #2
1) I’m sure their is but it won’t be easy or practical
2) yes and it’s fairly easy. The loader valve should have an adjustment. Probably and hex head and lock but type setup. In increases pressure. I’d spend the $25-$30 for a gauge with quick connect- it’s worth knowing how high you are going.
You will get flamed on here if you go over the manufacturer’s max pressure. But it has been done.........wink wink.
   / More Power ! #4
In earlier posts you repeatedly expressed reservations about your subcompact Mahindra Max28.
Part of this is likely the 1,800 pound bare weight tractor, part the greater ambition that comes with tractor experience.
Subcompact tractors are solid for what they are. Excellent first tractors. Easy to service yourself. However, you outgrow them.
You have ten acres. More tractor is appropriate.
Five reasons owner/operators trade up from Subcompact Tractors:
More tractor weight.
More FEL lift capacity.
Greater ground clearance
Three-range (3) HST (Lower LOW, Higher, HIGH) rather than two-range (2) HST.
Larger wheels and tires yield more tractive power pulling ground contact implements and logs, pushing a loader bucket into dirt and pushing snow.
Larger wheels and tires permit heavier tractors to bridge holes, ruts and tree debris with less operator and implement perturbation.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
VIDEO: So you want to TRADE UP for a new Tractor? - TMT - YouTube
   / More Power ! #5
Max28 with a 2-range HST additional horsepower will do little to gratify you save when tractor is powering PTO implements.
   / More Power ! #6
Gee, most of use could use more power! :thumbsup: Problem is, our tractors our auto's were designed for X amount of newtons, PSI or HP and when you add to it, something will break, wear out quicker or bend. Of course its cheaper to buy a larger, more powerful machine.....
   / More Power ! #7
ArlyA. . . yes and no . . . but sounds like the OP needs a bigger machine . . .
   / More Power !
Yes that is true and I apply the MORE POWER theory to all of my vehicles, with better breathing, a Computer Chip Change... etc..
But I am not trying to get 400 HP out of my little 28 HP diesel motor but one things is for sure, it is the same motor used in the 33 HP Tractors, maybe the 35s... ! So I am thinking 33 HP would be nice and a little more hydraulic pressure would be even better !
Now the problem that arises is... How Much is too much ?
That is what I did to find out and I have read here on this site that larger cylinders on the FEL and the BH will help a lot.
So, here I sit broken hearted, bought a Mahindra Tractor and I want more power ! I know the phase doesn't go that way but I am trying to be funny so I don't cry about not having enough power.
The Tractor is a 2014, bought it with 43 hours on the gauge, first thing I didn't like was NO POWER !
Once in Low Range, it does get the job done, so I can survive with her, but I need to do some investigating.
Thanks for the comments !
   / More Power ! #9
The dealer’s programmer supposedly won’t change one HP setting to another. And I don’t know what would happen if you ordered a 33hp computer. But like was stated above- more HP won’t really do anything for your general tasks. It would help if you had a specific PTO need.
   / More Power ! #10
Unless you install a larger hydraulic pump, larger cylinders will take longer to fill. 20% larger cylinders, 20% more time.
Excruciating time.
For ten acres a tractor of 2,700 pounds bare tractor weight to 3,800 pounds bare tractor weight is appropriate, depending on what proportion of the land will be worked and whether it is level or hilly.
   / More Power ! #11
Scrambler, click on my screen name for contact info..
1 thing to check BEFORE u go jackin the screws..
Is the shut off solenoid adjusted correctly.??
IT COULD BE holding the pumps control rack from reaching full power..
& again, contact me & we'll walk down that path..
   / More Power !
Thanks for the offer.
I will try to remember to contact you when I get back to the Tractor.
Honey-Do List is getting attention for a week or so, just to shorten it down some.
Thx
   / More Power !
I've been reading and watching videos about More Power !
One video stated that when looking for a larger tractor, to get the feel of an increase in power, you need to go at least 33-50% higher in power and weight.
Something for me to think on; my little Max28 does most of what I need, so all I need is to clean things up some, and be happy with what I have.
She is the right size for the space I have, the area is being opened up more every week, so what my actual future needs will be is up in the air.
I need to review all of the other power increase threads and see where they are going.
   / More Power !
Unless you install a larger hydraulic pump, larger cylinders will take longer to fill. 20% larger cylinders, 20% more time. Excruciating time.
For ten acres a tractor increase of 2,700 pounds bare tractor weight to 3,800 pounds bare tractor weight is appropriate, depending on what proportion of the land will be worked and whether it is level or hilly.
The Tractor weight thing goes along to with the videos I have watched and the things I have read, almost 50% increase.
I do not know a lot about hydraulics, that said, I always thought if the hyd-system was full there wouldn't be any lag time in response but now thinking on it, it isn't something I even considered.
Once I read a few more threads on this site, I will reprocess the info and decide what and where I am going !
   / More Power ! #15
:thumbsup: now that makes good sense . . .
2012 Freightliner Cascadia (A56438)
2012 Freightliner...
5' MOWER (A52706)
5' MOWER (A52706)
2012 Chevrolet Traverse LT SUV (A59231)
2012 Chevrolet...
1999 John Deere 7810 (A60462)
1999 John Deere...
2011 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2011 VOLVO A40F...
New Holland 3930 (A60462)
New Holland 3930...
