My Harbor Freight Quick Hitch
   / My Harbor Freight Quick Hitch #201
So what do you guys do if some implements are 26.5" or 27"? Modify????
I bought longer pins and shimmed my little 4 ft disc. An all-thread pin using an inner and outer nut would have worked too.
Expect some minor modifying like this to bring everything closer to 'standard'.
My other implements matched the width close enough to connect up.
I've read here of many owners who completed 'final assembly' of their HFQH by widening its base with a Hi-Lift jack. (Called 'Farm Jack' at HF.)
Note HF sells (used to sell?) two different width Cat I QH's plus a Cat II.
I suggest measure everything you own before buying one.
   / My Harbor Freight Quick Hitch #202
"So what do you guys do if some implements are 26.5" or 27"? Modify????"
I made a combination three-point trailer hitch and quick hitch adapter for my "non-iMatch" attachments.
   / My Harbor Freight Quick Hitch #203
I've treated mine pretty rough and have had no problems with it
   / My Harbor Freight Quick Hitch #204
Runner,
You wouldn't happen to have some more pictures of your 3-pt trailer hitch and quick hitch would you?
   / My Harbor Freight Quick Hitch #205
The post above is the first I've read of someone tearing one up. Has anyone else with a 40 hp or smaller tractor done this too?
I haven't had any problems with mine in the last yr that I'v had it. I use it with a box blade and my chipper.
   / My Harbor Freight Quick Hitch #206
"You wouldn't happen to have some more pictures of your 3-pt trailer hitch and quick hitch would you?"
The quick hitch adapter also acts as a mount for my boom pole.
Here are a few pictures:
   / My Harbor Freight Quick Hitch #207
I just printed out a 20% off coupon and going to pick me up the quick hitch. They advertise the 27.5" width now....
Just in case anyone needs it...
coupon
   / My Harbor Freight Quick Hitch #208
my tractor has cat 2 hook up and my implements are cat 1 so i use the lil bushings my question is i know the hitch hooks up to the tractor as a cat 2 ok no problem there but where the implement hooks onto the QH is that cat 2 also so i would still need the bushings on the equipment its not a problem to keep it that way would it be better to get the cat 1 hitch and drill it out to cat 2
   / My Harbor Freight Quick Hitch #209
Although my quick hitch is a speeco, I ran into the same problem with my Leinbach Yard Tool aka pulverizer. Here are some pictures of the mod.
Basically I just cut the 2 angle iron strips from the main frame and moved them inwards just enough the the black arms could match up on the outside of the angle iron. Hard to explain, easy to see. Also had to notch out the angle right underneath the pin so the hitch would be able to slide under and connect.
Now after doing all that, I am ready to sell the Yard Tool because I have replaced it with a Harley Rake. :)
   / My Harbor Freight Quick Hitch #210
Picked up the 27-1/2" cat 1 HF quick hitch on Monday with a $79.99 coupon. Just looked at my rear blade and it needs the hitch adapter.
Called HF customer service and it is $17.79 with shipping, expected arrival 5 to 7 days.
In the mean time, I'll work on sandblasting and painting the rear blade and making some of the mods that others have done to their HF quick hitch, like replacing the hook bolts with pins.
Fingers crossed that the pto shaft for the brush hog extends enough to fit with the QH.
Thanks for the ideas.
Bolt Bin (A57454)
Bolt Bin (A57454)
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
SDLanch SDLGC80 Electric Golf Cart (A57149)
SDLanch SDLGC80...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
PIPE RACKS (A58216)
PIPE RACKS (A58216)
2013 Dodge Durango (A53317)
2013 Dodge Durango...
