My Industrial Cabin Build
   / My Industrial Cabin Build #101
Sounds like failing the inspection turned out to be a good thing. Nothing worse then finishing a job and finding out months later that there is a leak!!!
Are you living there full time in an RV?
I just started a thread about radon mitigation. I bought the pipe for last night. But now I'm having doubts on my design plan. Do I need an inlet pipe for better airflow or should I only have an outlet pipe?
No, EddieWalker, I am in the RV on weekends and days off. But I'd rather be here at the farm than back home 100 miles away.
Since I'm in Crozet, having some chick and waffles (and the internet is stronger) I thought I would update some photos.
One d the two cleanouts that wouldn't seal
Replacing the elbow without destroying the rest of the line.
Replacing a sanT with a Wye for a vanity connection.
My bride clearing loosened dirt so we can get the needed depth for the insulation and the floorIMG_7957.JPG
Picking up supplies for today's work.
Waterproofing the foundation.
   / My Industrial Cabin Build #106
An adventure you all will remember for years to come :thumbsup:
   / My Industrial Cabin Build #107
For radon mitigation, the goal is to create a negative pressure under the slab so that the radon goes up the vent and not into the house. You do not want an external inlet pipe as that would make it harder to depressurize the sub slab space. Once you have the venting in subslab, then you need to determine if you need to put a radon fan in the duct by running a radon test in the basement (or main level if it is slab on grade) and seeing if you have an issue or not. If not, leave it. If so, then add the vent fan. Best to plan for the fan with access and power ahead of time as it is easy then.
For any leaking PVC fitting, the best solution to try is to goop it up again and again with pipe cement. It will seal up after an application or two (or three..).
Pipe dope is the thing to use for any threaded fittings. There are several types that stay flexible but seal a whole lot better than teflon tape. I use Harveys or whatever the local store has.
I forgot to mention, I pressurized both sides today and it holds fine. Looking forward to tomorrow and getting this monkey off my back.
Dstig, I used Vaseline. Pipe dope was my next choice for if the Vaseline failed but I was pretty sure it wouldn't. When I was a kid we had a 12 inch inline water filter that we always sealed with Vaseline and our water presssure was always very high.
   / My Industrial Cabin Build #110
Pipe dope is designed to hold pressure. I'm doubting Vaseline has "Rated to 200 psi" on the label... :D Use da right stuff.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2014 Infiniti QX60 AWD SUV (A53424)
2014 Infiniti QX60...
2-Seat Wooden Rocking Bench (A55853)
2-Seat Wooden...
JOHN DEERE 710J LOADER BACKHOE (A52707)
JOHN DEERE 710J...
