My pole barn...a solo affair
   / My pole barn...a solo affair
Eddie, Wedge40, Weldingisfun, and Twinwillows,
Thanks! Today I got the flashing up over the door rails.:)
Wedge40,
I sold the Ford 3055 to pay down on the Mahindra 6520 4WD w/ KMW 275 FEL and Bradco/Mahindra 511.:cool:
hugs, Brandi
   / My pole barn...a solo affair #63
Go Brandi
Great Pics!
I am inspired to start working on my barn now. I will go back and research your sizes.
Looking Good,
Carolina Girl - Michelle
michellesc7 said:
Go Brandi
Great Pics!
Looking Good,
Michelle,
Hi Michelle. Glad I could help motivate.;) However big you decide to make it....make it bigger.;) I already have thoughts in my mind to expand mine!:rolleyes:
hugs, Brandi
   / My pole barn...a solo affair #65
Hi Brandi,
Likewise I'm glad to see you take up the project again.
I've read about all your interruptions, but so is life, right? Hope you are getting by them alright. Also missed meeting you at the AG Fair...maybe next year.
I'm looking forward to the rest of your project.
I went ahead and worked on the back door header and tracks today. I did this because it takes two folks to join two rails with the track rail splice. One to hammer it home and the other to squeeze the other rail end. Luke gave me a hand and it popped right it like a glove. I removed the 2x6s at 8 and 10 feet and added doubled up 2x8s at the 10 foot level. I only have 20 feet from the barn to the back fence,so it is hard to get the Big RED Beast back there and the bucket square to the barn as a work platform. So I will need to rig up a platform in the bucket and support it with chains from the bucket hooks. Then I will be able to park the tractor beside the barn and work from one side of the bucket platform.
hugs, Brandi
   / My pole barn...a solo affair #68
bindian said:
I built a platform for my FEL bucket to work off of.;) It is described at http://www.tractorbynet.com/forums/showthread.php?p=1339997#post1339997
I now have almost all the upper roof metal installed.:cool: It has been fun and I am sore all over. Now I go back to work and rest for a couple of days!:)
hugs, Brandi
Your barn is looking good Brandi, wish that I was started on mine. Oh well someday.:( You know, that red sure would look sharp if it was painted blue.:D
Brian,
I could come out there and help you get it started in blue.;) But I am sure you couldn't handle me helping on the barn and Mrs. MVR at the same time.:rolleyes: One must be highly motivated to build your own barn.;) I am highly motivated to finish the barn so I can buy at least two horses, so a special friend and I can go riding.:D If it makes you feel any better, I plan on building a log house with a blue tin roof.
hugs, Brandi
   / My pole barn...a solo affair #70
Brandi,
Your barn is realy looking good.
Did you pour concrete? I remember awhile ago that you were planing on pouring a pad, but don't remember anything else on it.
I never seen a log home with a blue roof, but it sounds interesting. Have you done any research on log homes in your area? Here, Satterwhite is probably the biggest log home builder with allot of them all over the area. Log homes are kind of funny around here. They don't sell really good and are more of a specialty market. For those who love them, they have them, but they are hard to sell.
I've also done some work on them and it's always the same thing. The pine rots where water sits. The Satterwhite homes have the D logs that overlap on the cornes. Every other log sticks out. The tops of those logs are flat and sometimes the porch or roofing lines up just right with the top log. This is where I've run into the worse rot. You don't see it or even think about it until your log is half rotted out from water sitting there, or soaking in, over a dozen years or so.
We also have allot of humidity here, and I think that adds to the rot issue. If you don't seal those logs on a regular basis, the areas you miss will start to rot on you. I've had to replace and patch logs on the sides of homes that were easy to see didn't get sealed properly. The homeowner said they sprayed on the sealer every other year, but with a little garden sprayer. I think they either did it too light, or just missed areas. I don't know as the damage was pretty bad to some of the logs and not too bad on others.
For light repairs, I just remove all the rot and fill with Bondo. I can blend the Bondo to look like the logs with layers of stain so it's not too noticable, but in other areas, I have to cut out the bad logs and replace them. That gets expensive.
Up in Oklahoma, we rented a log home that wasn't really a log home. It was stick built, but covereind in log looking lap siding. You still have to stain and seal the logs, but if one rots out on you, it's a simple task to replace them. Another advantage to them is they are not structural, so replacing them is even easier.
If I lived in a dryer climate, I'd build a log home. I am considering covering my home in Hardi Lap siding and staining it to look like real wood. I did this with my hot tub gazebo and it looks great. People don't realize that it's not real wood until I mention it to them. Even then, they touch it and feel it for themselves to make sure. I like to play a game and ask what type of wood do they think it is. Most will touch it and guess something, but never Hardi. It will never rot, it's fire resistant, and bug proof. The question is how long will the stain and seal last on it? Most log homes have to be redone every other year. If I can go that long, then I'm in the same boat as if I had used real logs. If I can go longer, then I'm ahead of the game, but still never have to worry about rot.
Eddie
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE EQUIPMENT SEAT (A58376)
UNUSED FUTURE...
AGT Industrial ATK-B1000 2 Post Car Lift (A57149)
AGT Industrial...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
2019 PJ TRAILER 32FT GOOSENECK (A58216)
2019 PJ TRAILER...
