My pole barn...a solo affair
   / My pole barn...a solo affair #71
Eddie, some of the cement board siding can be bought prestained and cleared. Looks very good and has a warranty. I don't remember what company had it, but it was done up in Utah. That is the stuff that I want to put on my barn when I ever get to it. One other thing, shop around, I am going to get it out of Colorado, less than 1/2 price compared to here in California.
Brandi, actually no blue on my barn, when I do build it I am trying to make it look old, like maybe 100 years or so. Greys, browns, and some rust will be the prominent colors.
Hehe, rust is RED.:D
hugs, Branid
   / My pole barn...a solo affair #74
Branid,
I have been following your thread and you have built a very nice barn. I have saved your pictures for future reference since I will be building one soon. Mine will be more a barn/workshop.
Keep the updates comming.
David
EddieWalker said:
Brandi,
Your barn is realy looking good.
Did you pour concrete? I remember awhile ago that you were planing on pouring a pad, but don't remember anything else on it.
I never seen a log home with a blue roof, but it sounds interesting. Have you done any research on log homes in your area? Here, Satterwhite is probably the biggest log home builder with allot of them all over the area. Log homes are kind of funny around here. They don't sell really good and are more of a specialty market. For those who love them, they have them, but they are hard to sell.
I've also done some work on them and it's always the same thing. The pine rots where water sits. The Satterwhite homes have the D logs that overlap on the cornes. Every other log sticks out. The tops of those logs are flat and sometimes the porch or roofing lines up just right with the top log. This is where I've run into the worse rot. You don't see it or even think about it until your log is half rotted out from water sitting there, or soaking in, over a dozen years or so.
We also have allot of humidity here, and I think that adds to the rot issue. If you don't seal those logs on a regular basis, the areas you miss will start to rot on you. I've had to replace and patch logs on the sides of homes that were easy to see didn't get sealed properly. The homeowner said they sprayed on the sealer every other year, but with a little garden sprayer. I think they either did it too light, or just missed areas. I don't know as the damage was pretty bad to some of the logs and not too bad on others.
For light repairs, I just remove all the rot and fill with Bondo. I can blend the Bondo to look like the logs with layers of stain so it's not too noticable, but in other areas, I have to cut out the bad logs and replace them. That gets expensive.
Up in Oklahoma, we rented a log home that wasn't really a log home. It was stick built, but covereind in log looking lap siding. You still have to stain and seal the logs, but if one rots out on you, it's a simple task to replace them. Another advantage to them is they are not structural, so replacing them is even easier.
If I lived in a dryer climate, I'd build a log home. I am considering covering my home in Hardi Lap siding and staining it to look like real wood. I did this with my hot tub gazebo and it looks great. People don't realize that it's not real wood until I mention it to them. Even then, they touch it and feel it for themselves to make sure. I like to play a game and ask what type of wood do they think it is. Most will touch it and guess something, but never Hardi. It will never rot, it's fire resistant, and bug proof. The question is how long will the stain and seal last on it? Most log homes have to be redone every other year. If I can go that long, then I'm in the same boat as if I had used real logs. If I can go longer, then I'm ahead of the game, but still never have to worry about rot.
Eddie
Eddie,
Thanks!:) I haven't poured the concrete yet. I had around $900 dollars of siding laying in the future stalls and needed that space to move my zero turn mower and log splitter to clear the center floor to prep. for concrete. I still haven't decided to contract it out or gets friends and family over to do it.
If I find cedar or cypress is too expensive when I build, I may forget the log house down here. Your right. Too humid. I am really interested in the Hardi Lap siding you mentioned. That would be nice if it can mimic rough cedar lap siding. If the expense goes too high, I will go with a frame house with a "rough" sided outside. And save the expensive logs for inside. I have been researching log home information for a few years, but have stopped since building this barn.
There are a few blue roofed log homes in the area. I will try to take a photo or two. There are a couple of log builders in the area, but there is a log home company in Brenham that builds them that I would lean to if I contracted out. I think it would be a hoot to build my own house!:cool: I like the idea of a true log home because it stays very cool inside during the summer. A show home in Cleveland was getting power washed and they turned the power off early in the morning. That afternoon is was still nice and cool inside. That impressed me on the spot.
hugs, Brandi
hunterridgefarm said:
Branid,
David
David,
Thank you.:) I will keep the updates coming.
hugs, Brandi
   / My pole barn...a solo affair #77
brandi - you can get the same effect cheaper and better by building with 2x6 exterior walls, good insulation, and good windows. I researched log homes several years ago and they are just too darn maintenance heavy for me. I discovered they require too much of what I will call constant care. resealing joints, recoating with wood preservative, watching out for bugs & rot, they are always expanding, contracting, moving due to temp & humidity changes. It's not what I want to spend my time on in retirement. I'm hoping to build with stone & hardi. The stone will be wherever the weather can reach it and the hardi will be on the exterior walls of the porches. No painting, no movement, fire resistant, bug resistant, rot resistant.....you get the idea. And hill country stone is a good look too - still gives you that "Texas" look if that's what you're after. A blue roof would look good on top of it too.:D
   / My pole barn...a solo affair #78
One thing that will cut waaaay down on log home maintenance is to have very large overhangs. Also there are many types of log homes and they are not created equal.
Mike,
Like Brian (MountainViewRanch) mentions, a large overhang will help. Also, most log homes are on pier and beam foundations. I want mine on a slab with porch all the way around it. The second story can be the hardi plank or wood that Eddie mentions that looks like wood siding.
hugs, Brandi
Mikim,
   / My pole barn...a solo affair #80
hugs, Brandi
Brandi,
This is a house that I built last year for a client. It's done in Hardi siding that I painted, but could easily be stained to look like wood. Same with the posts and trim.
Eddie
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
UNUSED FUTURE 25MM MINI EXCAVATOR ATTACHMENT SET (A58376)
UNUSED FUTURE 25MM...
1998 Volvo VN T/A Dump Truck (A56858)
1998 Volvo VN T/A...
Polaris Ranger (A57149)
Polaris Ranger...
John Deere Z930M (A57149)
John Deere Z930M...
