Need French Drain Advice
   / Need French Drain Advice
Picture for option no. 3
   / Need French Drain Advice #13
Does a french drain just refer to a ditch filled with rock or does it also mean a perforated pipe?
   / Need French Drain Advice #14
I could be either, some don't use pipe.
   / Need French Drain Advice #17
A couple of surface drains would be nice for the winter rains when ground is frozen.
   / Need French Drain Advice #18
   / Need French Drain Advice #19
Use solid PVC pipe with holes, like found in leach lines. It is more expensive. But, if it ever needs cleaning, or gets a clog, you can run a snake down it. If that corrogated stuff clogs, your out of luck; no way a snake will fit. Or a hose... They just hang up on the corrugations. And, the corrugations hold silt really well.
   / Need French Drain Advice #20
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
Hyster H225E Forklift (A47477)
Hyster H225E...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2014 Dodge 5500 4X4 Bucket Truck (A55218)
2014 Dodge 5500...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
