Need French Drain Advice
   / Need French Drain Advice
Picture for option no. 3
   / Need French Drain Advice #13
Does a french drain just refer to a ditch filled with rock or does it also mean a perforated pipe?
   / Need French Drain Advice #14
I could be either, some don't use pipe.
   / Need French Drain Advice #17
A couple of surface drains would be nice for the winter rains when ground is frozen.
   / Need French Drain Advice #18
   / Need French Drain Advice #19
Use solid PVC pipe with holes, like found in leach lines. It is more expensive. But, if it ever needs cleaning, or gets a clog, you can run a snake down it. If that corrogated stuff clogs, your out of luck; no way a snake will fit. Or a hose... They just hang up on the corrugations. And, the corrugations hold silt really well.
   / Need French Drain Advice #20
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A54313)
2003 VOLVO VNL...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
Brent 420 Grain Cart (A55301)
Brent 420 Grain...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
