Need French Drain Advice
   / Need French Drain Advice
Picture for option no. 3
   / Need French Drain Advice #13
Does a french drain just refer to a ditch filled with rock or does it also mean a perforated pipe?
   / Need French Drain Advice #14
I could be either, some don't use pipe.
   / Need French Drain Advice #17
A couple of surface drains would be nice for the winter rains when ground is frozen.
   / Need French Drain Advice #18
   / Need French Drain Advice #19
Use solid PVC pipe with holes, like found in leach lines. It is more expensive. But, if it ever needs cleaning, or gets a clog, you can run a snake down it. If that corrogated stuff clogs, your out of luck; no way a snake will fit. Or a hose... They just hang up on the corrugations. And, the corrugations hold silt really well.
   / Need French Drain Advice #20
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2018 Chevrolet Colorado Pickup Truck, VIN # 1GCHSBEA6J1312961 (A54865)
2018 Chevrolet...
Utility Trailer (A52377)
Utility Trailer...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
