Need French Drain Advice
   / Need French Drain Advice
Picture for option no. 3
   / Need French Drain Advice #13
Does a french drain just refer to a ditch filled with rock or does it also mean a perforated pipe?
   / Need French Drain Advice #14
I could be either, some don't use pipe.
   / Need French Drain Advice #17
A couple of surface drains would be nice for the winter rains when ground is frozen.
   / Need French Drain Advice #18
   / Need French Drain Advice #19
Use solid PVC pipe with holes, like found in leach lines. It is more expensive. But, if it ever needs cleaning, or gets a clog, you can run a snake down it. If that corrogated stuff clogs, your out of luck; no way a snake will fit. Or a hose... They just hang up on the corrugations. And, the corrugations hold silt really well.
   / Need French Drain Advice #20
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
