Need help idintifying motor mounts for an 8.3L Case built Cummins.
   / Need help idintifying motor mounts for an 8.3L Case built Cummins.
Holding the 1:1 plot of this bolt pattern up the motor as best I can, it appears that the top holes and the lower left hole are correct while the lower right hole may be off a bit. It's hard to tell with the paper template. The way the holes on the drivers side are located, it leaves very little room for meat on the plate. I think I'll just make some straight plates for the sides and be done. I should have some time this weekend to play. I've got more irons in the fire than I even had fires right now. Thanks for the help, all.
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
