Need help idintifying motor mounts for an 8.3L Case built Cummins.
   / Need help idintifying motor mounts for an 8.3L Case built Cummins.
Holding the 1:1 plot of this bolt pattern up the motor as best I can, it appears that the top holes and the lower left hole are correct while the lower right hole may be off a bit. It's hard to tell with the paper template. The way the holes on the drivers side are located, it leaves very little room for meat on the plate. I think I'll just make some straight plates for the sides and be done. I should have some time this weekend to play. I've got more irons in the fire than I even had fires right now. Thanks for the help, all.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
207269 (A52708)
207269 (A52708)
