New Driveway and Polebarn
   / New Driveway and Polebarn
Ok .... it's coming down to the wire for me - Cleary is scheduled to be out here this coming Monday to start putting up the polebarn.
I have been trying to get my pad graded and leveled out but the weather hasn't been cooperating too well over the last several weeks .... a good bit of rain and cool temps. Fortunately I've got it graded enough that there aren't as many holes/depressions and there is enough slope that most of the water is flowing to the bottom corner of the pad, opposite of where the building will be.
I've also managed to get a good part of the trenching done for the french drains around the building - particularly the back side, since once the building is up I won't be able to get back there with the backhoe. (The area on the back side of the building is about 3' below original grade and there is another 6'+ of topsoil piled up on the original grade at the moment - the building will sit out in the excavated area about 5' or 6' from the edges.)
I'll be trying to get the french drains installed in the 300' or so of trench I currently have dug before Monday. There's another 200' of french drain to do beyond that, but it can be done after the building is up. The french drains are 16" wide and the depth is probably 14" to 16" (minimum), multiple runs of 4" perforated flex draining to 6" perforated flex, both with soil sleeves, laid in No. 57 washed gravel (or coarse sand ?), encased in non-woven geotextile. The 4 downspouts from the gutters will be tied in as well. The entire perimeter of the building will be covered with at least several inches of gravel, and the parking/driveway area in front having probably at least an 8" depth.
One area of concern that I have is the ground settling. A good portion (2/3rd's to 3/4) of the building will sit on undisturbed clay - the southwest corner (1/4 to 1/3) will set on an area which had the topsoil removed and then was backfilled with clean clay (excavated from the other end of the building.) The area was backfilled using fairly shallow lifts (less than 6" for the most part) and was compacted by driving over it with a Bobcat 743 and Kubota B2910. I would estimate that the depth of the fill, under where the building will be in that corner, to be 4'± at it's deepest point. It has rained twice now since the area was filled and the area has been run over a bazillion times while I was boxblading it ..... for the most part it seems pretty solid (although if you head a little further south it gets mushy)
Should I be concerned that the area needs further compaction ? I was originally planning to bring in a 4.5 ton vibratory padfoot roller and whack it with that .... although that plan has sort of fell by the wayside due to rain and lack of time.
I am planning on having the floor concreted after the building is erected - probably something on the order of a 4" to 6" slab (using a 6 bag/4000 psi mix) with the edges thickened to 10" to 12" and 1/2" rebar every 2' on chairs in a 45° diagonal lattice pattern, with a double run of rebar (stacked) in the thickened edge. This sound right ? And I was planning on extending the pour beyond the poles, outside the building, by at least several inches, with a dropped lip at metal siding.
The poles (3-ply 2 x 6 nail-laminated) will be set in Post Protectors, which are 60" long. Cleary wants to set the poles to at least a depth of 52". It was my intention to have them leave approximately an extra 12" of pole exposed (meaning they would initially be set at around a 40" depth) - to allow for a base below the concrete slab and the slab itself - once the floor was poured I would backfill around the perimeter of the building.
Question on the base under the slab - sand or gravel ?
I'm open to any thoughts or insight anyone might have on the above - this is the first time I've every attempted anything like this and I'm suffering from a serious lack of previous experience. /forums/images/graemlins/grin.gif
About a week or two ago, when it was too wet to be back on the building pad, I managed to get most of the torn up asphalt from the old driveway spread out on the road extension. There were lots of large chunks .... some as big as 2' x 2' and 6" thick ..... no way you could take a normal vehical over it.
This past Tuesday I had Roger bring over his Komatsu dozer and run over it to grind it up for a base for the road. He was here for a couple of hours ..... it turned out way better than I expected.
This is where the road extension meets the new drive. Roger did a pretty good tying it in ... I've since dumped some more ground up asphalt and cinders on it.
This what remains of the asphalt pile .... it used to go all the way up to the pile of dirt in middle upper left of the image. This remaining asphalt will be used for a low area where the new drive joins the old, down by the house.
Reverse angle.
This is the bundle of whitewood for the barn.
The trusses.
The PT poles, sheetmetal, foundation "cookies", and other odds and ends.
Last one. Somebody had a couple days off school and was looking to help out (in exchange for a little seat time ..... /forums/images/graemlins/grin.gif ..... how could I say no ?)
The building pad was still pretty wet from the rain the other day .... so we spent most of the day mining clay out of the old driveway base which was pretty dry) and Zack hauled it down to the pad in the Gator. He also went home and got his leaf vac and picked up the leaves (most of them anyways) Am I lucky or what ?
   / New Driveway and Polebarn #80
Randy that drive where you used the blacktop is really starting to shape up nice. It's amazing what the dozer was able to do with those large pieces. Once you top it with the fines it should be perfect.
I'll be stopping by this weekend to check your progress but from what I've seen in this thread so far I'm impressed.
Caterpillar 262D3 (A57148)
Caterpillar 262D3...
2016 Case 580N EP Backhoe, S/N JJGN58EPLGC729072, Diesel Engine, 4 x 4, 80" Front GP Bucket, 22" (A59076)
2016 Case 580N EP...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2022 FORD F-250 (A58214)
2022 FORD F-250...
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
PALLET OF MISC PARTS (A52708)
PALLET OF MISC...
