new owner of 5000, questions
   / new owner of 5000, questions #31
if you were in florida.. yeah.. :)
as for the tire.. it will say what size rim it wants.
dishing? not all rims are offset.. but many are. if offset you can flip them out or 'dish' them.. makes the stance wider.. steering a lil tougher, and generally moves the tire a good ways away from the front spindle knee.
my 7610s uses 10-16's my 5000 has 7.5-16 on it I believe..
soundguy
so can anyone tell me if the low pressure fuel lines on this machine are reverse flare (like brake lines?) or standard flare, or something altogether different?
I'd like to know before I go removing one to check it out. the nut is mostly stripped and I'm not going to screw around with it if I'm not going to be able to put together a repair piece quickly and easily.
Thanks
karl
S#$% Transmission needs rebuilding.
I should have taken pics, but the internals of the shift mechanisms look like someone went in there with a prybar. forks are bent, every connection wiggles, the tops of the forks have been brazed to replace the worn away metal.
The only good thing seems to be that the gears don't appear to be worn too badly.
does anyone have good sources for internal parts or good transmissions?
it's kind of a crap shoot I know, trying to find a good 40 year old transmission. this one had a loader on since new and it's probably about done.
K
   / new owner of 5000, questions #34
i'd try wengers of pa. might be easier to find an intact 8spd vs parting one together..
soundguy
   / new owner of 5000, questions #35
There is a local salvage yard here that may be worth a try. Graham Imp. 270-932-5727. Tell them I said contact them. Ken Sweet
progress,
the trans fluid and the rr axle fluid/hydraulic fluid was full of water, kind of off brown with white.
I replaced with Mystik JT-5 UTF, and the trans shifts a whole lot better than it did. this oil is significantly thicker than what came out (probably due to the water) and I'm wondering now, if I should try something a tiny bit heavier.
I don't want to put in synthetic gear oil, 4 gal at $6 per qt would hurt.
could I just add a quart of gear oil and expect it to mix? this oil just stays in the trans, so shouldn't hurt anything else. what about something like the lucas oil stabilizer? thick stuff.
my logic is: a bit thicker was a lot better, might even thicker be still better?
I've asked one person who's opinion I respect, but I'd like to see what y'all think.
thanks
karl
   / new owner of 5000, questions #37
   / new owner of 5000, questions #38
They were not designed to be shifted ont he fly.. period. the fact that some can or do does not change the fact that the trans was designed to start in the gear of choice then run.. and to come to a stop to shift again. it is not a full synchro power shift tranny no matter how much you might want it to be.
to the other poster.
utf is fine in everything on a 5000 except the engine and air filter.
soundguy
Thanks
I driven lots shifting full synchro trannies with no clutching, and have a couple of times shifted the 5000 without stopping, but don't plan on it. if nothing else, without a foot throttle, I don't have enough hands to make it happen smoothly.
Karl
   / new owner of 5000, questions #40
I also just recently bought a 5000 and I have a similar problem with the reverse jumping out of gear. I have found that stopping completely and then double clutching and then into rev. works quite well. I have changed the tranny fluid and just topped up the rear diff. level. A special thanks to "Soundguy" for his guidance.
Jim
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56436)
Greenworks...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Deere 335P (A53317)
Deere 335P (A53317)
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
