New Pole Barn project getting started.
/ New Pole Barn project getting started.
rockshaft said:
Sometimes you need the little dudes to fit in tight spaces. :)
Looks like a good worker
Yep, he's my little tractor freak. According to him, the L3130 is his and he just let's me use it until he can drive it without me. Very thoughtful of the boy. He drives my cub cadet zero turn mower (not with the mower engaged of corse, his mother forbids it) better then my wife. He is very cautious and has never run into anything. He has a little 4 wheeler of his own but prefers to drive my wife's Yamaha 350. At 5 yo he can operate the backhoe ( and do it very well), drive a dozer and operate a mini excavator. He knows that you have to work hard to get the things you want.
My little man. Sorry that these are off topic
/ New Pole Barn project getting started. #63
Darrenone, Looks great! FWIW I would add quite a few diagonal braces to the underside of the trusses to keep them from folding over in high winds. It looks like you have a few in place but the more the better. The diagonal braces will really tighten the trusses up and make it a lot safer, and only costs a few bucks for the 2 X 4's. Just my 2 cents of course!!
Thanks srs. Before we left for the day we added quite a few diagonal braces to the trusses for just the reasons you mentioned. Last summer a huge pole barn 10 miles from me had all the trusses blown over and it was a disaster. I want to get all the permanent purlins on and all the bracing on as quick as possible. Just not as young as I once was and climbing the trusses is a much slower process now. I do appreciate the input as I appreciate all the help I can get.
/ New Pole Barn project getting started. #65
I added two strong backs (one flat 2x4 and a 2x4 on each side sitting on its side) which formed a trough - placed one along each future row of lights (on top of the bottom rafter). Really added strength to the roofing system plus made a nifty wire tray.
I have also used it as an anchor point a few times to hoist something out of my truck (before my FEL was purchased).
You can fab sections on the ground, staggering the joints of all three boards.
Ok, I worked both Saturday and Sunday and only managed to get the purlins up. Frustrating but at the same time it is progress.
Progress is frustratingly so but we are gaining.
/ New Pole Barn project getting started. #68
With that big tractor you have there you could have easily made a jib and set those trusses by yourself and saved even more $$$.
That's what we did: Strapped a long 4x4 alongside 1 of the long teeth on my grapple-bottom bucket, attached trusses to it 1 at a time, & lifted & set them in place. Worked very well. Poles are 16' tall (above ground) & trusses are 4/12 slope which equated to 4' tall in the middle, so total height jib had to reach was ~20'. That was about the extent of what my jib concoction could reach, but if it needed to be higher we would've just made a longer jib. Trusses don't weigh much individually, not mine anyway (24' long trusses span + 2' overhang) .. I could carry 1 by myself ... just couldn't lift it 16' high :)
/ New Pole Barn project getting started. #69
Very cool project, thanks for sharing so much about it.
For the two tone tin on the walls.
Is the lower piece still metal, or is that a no rust plastic thing?
Hey Daronspicher, thanks. The lower section is the same metal as the upper. The ideal is just to break up the wall and hopefully look a little nicer. No other reason
Hey beppington, I seriously consider doing this but didn't want to find out it wouldn't work when I had help standing around. My trusses where 42' long with a 6 1/2/12 pitch on top and a 3/12 underneath . They were heavy enough that two people couldn't pick one up and carry it. Plus, the building was 12' and the trusses another 12' for a total of 24'. I just wasn't sure if the tractor would handle it. The truss company didn't do me any favors when they dropped the trusses as they put them on the side of the building. It just seemed easier and safer to lift them up over the wall and them swing them in place.
/ New Pole Barn project getting started. #72
Darren,
Would you mind if I stopped by to look at your barn sometime?
Kevin
kevincook said:
Darren,
Kevin
Hey Kevin, you can stop up any time. Drive up Meeker and you can't miss it. Bring a hammer! Laughing!
Decided it was best to do the concrete floor before all the walls were up because the concrete trucks will not fit under my door opening. I was going to hold off because of money but it will be so much harder later. So, I've been preparing the floor trying to level it up with stone.
Took a few picture this morning at about 7:30 of the fog that settle in the valley. Pretty.
/ New Pole Barn project getting started. #76
Very pretty, indeed. Also pretty is your neighbors pole barn! Bet that has been a motivating factor in your own construction, no?
Thanks deezler, my neighbors barn has been an inspiration but reasons other then you would think. His is about 24x40 and I'd be willing to bet he paid more for his then I will have in my 40x60. Don't get me wrong, his is very nice, probably nicer then mine will be, but he paid a local pole barn company to build his and they are very expensive. They do great work but are expensive. Now, he is some sort of doctor so money is a bit better for him then me. His was also done in 5 days to mine going on a long time.
Ok, now I have a concrete floor which makes it much nicer. Alot of work but it came out good. The concrete guy busted there butts. That's my son sitting in one of the trucks. 32 yards to do the floor about 4 inches. I sealed it right after they finished it. Needs one more coat which I will mix with the fine sand material so it won't be so slick when wet. Happy that part is done.
ENG18LT said:
Darren, looks great!
Thanks, the floor should make It much nicer inside now.
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
10x20 Barn Style Shed (A62613)
10x20 Barn Style...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2017 TROXELL  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
2021 Kawasaki Teryx KRX 1000 SE (A62679)
2021 Kawasaki...
