New Pole Barn project getting started.
/ New Pole Barn project getting started. #81
Ok, now I have a concrete floor which makes it much nicer.
Darrenone, concrete looks really good. What is the black material near the bottom of the sill behind the metal siding?
Thanks. That is tar paper normally used on roofs. They recommend that you don't put the metal right up against pressure treated lumber so I took a role of tar paper and cut it into 1 foot sections.
/ New Pole Barn project getting started. #83
Makes sense, thank you. Stanley
I haven't posted in a while so thought I would update with a few more pics. This project goes along with a house I will be building there too. Well, we have accepted an offer on our current house and will be starting the new house as soon as we can close. Probably some time in August we will start digging for the new house. This will leave us homeless for a time but with family close we will get by. We also set up a tent at the property and can stay there some.
The barn has been coming along but slowly. We really need to get it finished soon as we are going to store our house items in there until the new house is completed.
/ New Pole Barn project getting started. #85
Darren, the barn is looking great!
/ New Pole Barn project getting started. #86
Darren, thank you for the update. I have been following this post sine the beginning and appreciate the updates. Your pole building looks great and while slow and sometimes frustrating...it has to feel great to do so much of the work yourself.
Thanks for the kind words and I will try to do better with the updates. I still need to install the metal on the last wall and then do the soffits and facia. Then I will get started on the shop walls and mezani. We are also planning the house and trying to line up the utility company to get power hooked up. As the barn is about 500' from the road, we have decided on a transformer on the property mid way to the barn. From there, I will run to an outside panel and then to the barn and house. Also pricing out poured concrete walls for house basement. Our house has sold but waiting to close before we can get loan for new house. Going to be very busy for the rest of this year until house is done.
Well, I am getting closer to having the building closed in. It just takes along time working alone but it is what it is. I am now thinking about a layout for my wood shop which will occupy a 20x40 area in the barn. Anyone have any good layouts for a workshop with these dimensions? Trying to plan a layout to figure things like where the electrical should be. Also want a 60 gal. Air compressor somewhere in shop that I will hard pipe to various locations. I bought a few 8' HO T5 light fixtures and put two of them up in the 40x40 garage part just to see what they would look like and how much light they give off. I was amazed at the light these fixtures produce. I think I will put 5 of them in the garage part and that will be very well lit up. The work shop will have a nine foot ceiling in it with storage up above. I think 3 of these light fixtures in there will be plenty with maybe some additional lights over work bench and table saw. Anyway, here is a few more pics and any thoughts or ideals are greatly appreciated.
Darren
Well, pole barn is mostly done on the outside, have one side and one end to finish the soffit and facia. We are closing on our house this coming Friday and will be starting to dig our basement for the new house this week. Have been working on digging the water line to the barn from the well that will also be going in this week. Also working on the electrical line from the shop to the pedestal that I built for the outside panel and meter. We are having a transformer set on property because of the distance to the barn. The wife has been busy packing the the house stuff up and then we move it up to the barn for storage. A lot happening all at once.
Forgot the pics.
/ New Pole Barn project getting started. #91
Darren, it looks great.
Thanks Kevin, you need to stop up again as we are digging our basement right now and construction on the house will follow. Still need to finish soffit and facia but been busy with house things. Will be homeless as of this Friday so need to move along the house process. You never realize all the crap one has until you have to move it all.
/ New Pole Barn project getting started. #93
Great project Darren, what did you use to attach the sidewall headers to the posts? Also it looks like there is a 2x12 on top of a 2x6, are they connected somehow?
Thanks and I just nailed the sidewall headers up using # 20 nails and lots of them. As the rafters are tied to both sides and the 45* pieces are also nailed in between from both side it seem acceptable. All the force against it should be straight down and therefore would have to shear the nails off. I had the building engineered and this is what they came up with. Also the 2x12 + 2x6. Seemed like over kill to me but did it anyways.
Darren
/ New Pole Barn project getting started. #95
Darren
That's pretty standard technique. I also put blocks under my headers that bear on the girts below, also used big honking ring shank nails that came with barn. Never saw one beam on top of another like that, interesting idea to get some extra strength. I would have thought they would use three headers instead of two and let one into the post. But they're the enginerds, they must know what they're doing.
/ New Pole Barn project getting started. #96
Looks great!!! Just my experience, a 9' ceiling can be difficult flipping 4x8 sheet material around. You do what you need to do though.
MarkV
MarkV
I agree with you Mark. My thoughts were that I wanted to be able to put things up above with the pallet forks of the tractor. I can only reach 8' with the pallet forks and I knew that would be to low for the shop ceiling. So I went with 9' ceiling and will build a platform at 8' that the stairs go up to and at least be able to set a pallet at that height. Kind of a compromise but hopefully it will work out.
Darren
Well the exterior of the pole barn is complete and I built my 20' x 40' shop inside that is insulated walls and ceiling. Unfortunately, it will have to stay as is right now as we have moved all our stuff from our house we just sold into the barn. Barn is very small right now, can't even get my tractor inside. Now begins the building of new house. Hope I have the strength to get through the next few months.
Darren
/ New Pole Barn project getting started. #99
Good luck with the house build. My wife and I built a house last year and while there were some stressful times overall it was a lot of fun.
Thanks wmonroe! Yes, building a house can be very stressful but I am going to try to enjoy the process. It is just physically tiring as I will do alot of the work.
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
FORD 2810 TRACTOR (A64277)
FORD 2810 TRACTOR...
2023 Bobcat E88 Excavator (A65579)
2023 Bobcat E88...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
