New to me TC29D cranks & won’t start
   / New to me TC29D cranks & won’t start #31
Interesting as ever one I have ever seen for diesel engines goes up to 1000psi. That engine should be close to 500psi certainly more than 300psi.
Edit: From what I found the pressure range shows to be 350 to 425 PSI for the TC29D.
   / New to me TC29D cranks & won’t start #32
To test the glow plugs with the multimeter, disconnect the plug wire/strap/bar that connects each of them together, and measure the resistance(ohms) of each one between the connector post and the engine block.
Yes, the compression is tested through the glow plug holes with an adapter. Harbor Freight has a reasonable price diesel compression test kit with the correct glow plug adapters. Be careful removing/reinstalling the glow plugs -they are not as robust as spark plugs and a broken off plug is a PITA.
After you have the gauge connected, pull the wire to the injector pump solenoid and crank -the gauge will hold at the highest compression reading. If it's low, remove the adapter out of the glow plug hole and squirt in about a tablespoon of engine oil through the glow plug hole, replace the adapter, and test again. If the compression goes up, it's the likely the rings are bad. If no change, it's likely a valve issue.
My vote with the info available is for bad rings being likely. These can usually be changed without splitting the tractor by pulling the head & oil pan.
You are getting smoke on cranking and you are getting spurts when the injector lines are cracked -this doesn't necessarily mean it's absolutely not a fuel issue but it's less likely.
   / New to me TC29D cranks & won’t start #33
Thats correct but the gauge doesn't say for diesel engines. My pressure rating was off. I stand corrected.
   / New to me TC29D cranks & won’t start #34
Read post 23 Lou. Or can't you read. It say you cant use a compression tester on a gas engine.
Read the second line, or can't you comprehend two sentences together.
Ladies ladies I take full blame for that pissing match apologies everyone. I should have phrased my post that I have a harbor freight diesel compression test kit in hand along with the multimeter…
I did not get to the tractor this weekend I was running our 1964 caterpillar 12’ blade road grader fixing our roads up for the season.
Took longer then expected sorry for no updates. Tomorrow after work I’ll get some testing done
Thanks everyone!!!!
There’s a whopper of a post copy that
Will do to everyone in the help testing GPs as well as DIESEL engine compression testing.
I will also follow up on on the tablespoon ish squirt of oil in each cylinder IF compression is low.
Is replacing bad rings something I can accomplish myself with the community help here and some university of YouTube videos???
I do have a small shop!
THANK YOU AGAIN EVERYONE!!
Encouraged tonight!
   / New to me TC29D cranks & won’t start #37
Well I am not a diesel mechanic but I knew right
away he was saying that a gas engine compression
unit will not work to check the compression on a diesel.
petrol engines have a CR of 8–10, while diesel engines have a CR of 15–20.
willy
   / New to me TC29D cranks & won’t start #38
Injection pump
   / New to me TC29D cranks & won’t start #39
THAT certainly would be the lesser of two evils..($$$)
between an engine o/h and an inj pump o/h..
   / New to me TC29D cranks & won’t start #40
Even with a bad injection pump or glow plugs it should at least kick with ether spray. To check glow plugs, remove and lay them on the block or ground them with a jumper then with them cycled on check to see if they get hot and glow. You could also just connect them to any 12v dc battery and do the same. My suspicion is low compression due to worn rings but I am just a back yard mechanic
4 Pallets of Vehicle Seats (A53425)
4 Pallets of...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2003 PETERBILT 330 MINI DUMP TRUCK (A55745)
2003 PETERBILT 330...
