NH 7308 Loader Owners
   / NH 7308 Loader Owners #21
Re: Can you lift your front tires now?
I'd like the gauge sent to me as well. /forums/images/graemlins/smile.gif
I found it easier to access the lock nut and set screw by first removing the knob, boot and shroud. The shroud is held on by three 13 mm bolts.
I turned the set screw in 1/4 turn which, according to Spencer's experiment, should equal 125 psi more.
   / NH 7308 Loader Owners #22
Ok, here is some info.
SV of tractor showing valve and hose connections (TC30)
   / NH 7308 Loader Owners #23
Closer up view
   / NH 7308 Loader Owners #24
TV (top view) of valve
   / NH 7308 Loader Owners #25
If you are really talented you can adjust the setting without taking off the metal valve cover. if not, you will need some bendy tools to get at the screw on the side of the cover.
   / NH 7308 Loader Owners #26
Using a 1/2 in wrench and allen wrench at adjustment point.
   / NH 7308 Loader Owners #27
Here is a view of the gauge installed.
   / NH 7308 Loader Owners #28
another view (top)
   / NH 7308 Loader Owners #29
First reading. Note, the instructions call for running the engine at a high rpm (2600 I believe). I found that running and testing at this rpm produced a spike in pressure of an additonal 300 psi which then bled down quickly to the relief pressure. I tested mine at my usual operating speed of 1500 rpm and got the same reading without the spike. Test yours as you see fit.
   / NH 7308 Loader Owners #30
After adjusting down from 2100 psi. Ooops, too low !
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
2015 John Deere 35G Mini Excavator (A49461)
2015 John Deere...
2024 Iron Bull 20ft T/A Equipment Trailer (A49461)
2024 Iron Bull...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
