Oledadger
Re: OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor?
ok how tall is your dolly?
Looks the same.
Looks the same.
Yours looks completely different. For starters my 3pt has to be removed before I even start. It's tight for space back there. I mean really tight.Here's my little lawn mower. I'm 65, maybe I'm missing something, but it should go on easily. I think pictures would help to figure out what's wrong. I just removed mine, then back on. Tractor now has 110 hours, hoe maybe 15. It's easier each time. As someone suggested I think something is bent, out of line, worn, etc.
I just use stabilizers and roll the lawn mower back and forth as needed. Easy.View attachment 557407View attachment 557408View attachment 557409View attachment 557410
It's like sex, you need to lubricate the mating joints. Axle grease smeared on contact points is a recommended step in the manual for my KMW 3710 backhoe.My woods was a real pain the first few times, even after I learned how.
Seems like after using it a few times, the tolerances between all the parts loosened up and it got better.
I sure wished I was there to see it. Something is obviously wrong, it shouldn't be that tight clearance either. I keep a zippered canvas bag mounted under seat which holds lots of tools, pins, etc. So I easily and quickly can loosen hitch turnbuckles out of the way, then adjust for Bush hog, etc.
It should be almost effortless.
No, it's not near as fun. I tried spitting on the hoe, but it still didn't fit.It's like sex, you need to lubricate the mating joints. Axle grease smeared on contact points is a recommended step in the manual for my KMW 3710 backhoe.
