Plans for removable canopy comments
   / Plans for removable canopy comments #1
bnixon
Houston, Texas
TC33D / 7308 ldr 60" HD bucket
I have been thinking (This usually gets me into trouble! /forums/images/graemlins/tongue.gif). Here in Houston the sun and heat in the summer time..well all of the time /forums/images/graemlins/crazy.gif, is enough to make you not want to get any seat time. So I decided I needed a canopy.
My dilemma is two fold.
1) The cost of manufactured canopies are beyond my reach! /forums/images/graemlins/mad.gif
2) I have to have one that can be removed really easily. I have a huge oak tree that I mow under, every week, and there is no way to get it done with a canopy.
So here is my first pass at a design. I kind of took the John Deere quick attach bucket idea and adapted it to a canopy.
take a look and give me some feedback. I will be making it from small square tubing and light gauge sheet metal to keep it light (I don't know how to weld on aluminum with a stick welder /forums/images/graemlins/frown.gif)
Give me some feedback as this group has more great ideas than you can shake a stick at!
thanks,
   / Plans for removable canopy comments #2
Looks pretty sweet to me!!! Be sure it gets a coat of blue on it to match.....
   / Plans for removable canopy comments #3
Hello,
It looks nice, but I would build it solid and take a chainsaw to the offending limbs on the tree until you have the needed clearance.
Not in this case!
This oak tree is over 100 years old and about 7ft in diameter at the base. It has the low drouping limbs with the moss hanging from them. To cut these limbs would just be WRONG!
So I need a removable solution.
   / Plans for removable canopy comments #5
You can get Aluminum stick rod. I've used it, it works pretty good.
   / Plans for removable canopy comments #6
Bnixon:
I personaly see nada wrong with your idea, looks great to me and fairly simple to take off and on. You have the pivot point that it will hang on and pivot up on to put that pin in could be done easly by on guy.
I do think welding would make the whole project look better than bolting but, either way should do you just fine.
Allost forgot.....before I post this I did see some canvus tops made by DIYguy (check his web site) maybe something to look into before you go out buying alumn. and it would be light to boot.
Whiskey
   / Plans for removable canopy comments #7
I love the design. It's good enough to steal. /forums/images/graemlins/grin.gif The ONLY thing I see that I'd ask you about is the piece coming down from the large gusset on the canopy frame to the pieces attached to your ROPS. If that's drawn to scale, I wonder if that piece couldn't be a bit larger. Then again, I tend to overbuild everything. /forums/images/graemlins/crazy.gif /forums/images/graemlins/smile.gif
By the way, what did you use to draw this and post it? It looks really nice and I'd love to be able to do something like that instead of writing two pages to explain something. /forums/images/graemlins/smile.gif
   / Plans for removable canopy comments #8
You could always use a push mower under the tree, less seat time but a lot less work than removing the canopy each week.
   / Plans for removable canopy comments #9
Looks great!
Please post pictures of the finished product.
   / Plans for removable canopy comments #10
</font><font color="blue" class="small">( less seat time but a lot less work than removing the canopy each week. )</font>
Unless the tree is out in the back 40! /forums/images/graemlins/shocked.gif
I like your idea. /forums/images/graemlins/grin.gif I'm going to be needing something like that once I get my tractor, because I'll never know from job to job whether I'll have to worry about overhead clearance or not. It would be nice to have a canopy that a guy can get on and off easily by himself.
You can send me the "detail" plans once you get them all drawn up! /forums/images/graemlins/wink.gif
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
2023 Ford Expedition SUV (A59231)
2023 Ford...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
Towable T/A Flammable Liquid Transport Tank (A59228)
Towable T/A...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
