Plasma cutter question?
   / Plasma cutter question? #41
BHD. What did you order in the way of sheet metal shear? Us tool guys gotta know these things.
I ordered a guillotine shear, that was listed as 39" but when it came in it will only cut 30 -32"" which was a disappointment, the over all length was about 39" (in my opinion a misleading description),
it was about $260.00 with the shipping, similar to this one, Manual Guillotine Shear 32" x 16 Gauge Sheet Metal Plate Cutting Cutter w/ Stand | eBay and then I added a table, to the left of the blade, and added straight edge, and a clamping system, and a stop for repeated cuts, And remade the stand so one could extend the cut if needed, something similar to this, Heavy Duty Fully Cast Iron Manual Arm Guillotine Shears
some pictures of the shear and the add on's
   / Plasma cutter question? #44
Nice job with the table and add ones BHD!
Are you happy with it’s performance? Capacity as claimed?
a few of the other things I have been workin on, remodeled the stand for the bead roller, as I am making a fence for it and the stand was in the way, a rolling shear, made the stand for it, used a lod 16.5 rim, a vice stand, this is my welding vice, if I need to I can make tabs to bolt it to the floor, but don't know where I think it would be best location, the welding table out a plate of 1" by 24" steel,
a set of shelves, on one wall,
DCP_6777.JPGDCP_6776.JPGDCP_6775.JPGDCP_6774.JPGDCP_6773.JPGDCP_6772.JPGDCP_6771.JPGDCP_6770.JPGDCP_6778.JPG
really have not had a chance to use it yet, so as to how I like it I really can't say, I am sure as with most of this type of tools the capacity is over rated, "at least for ease of use"
2025 GPS Trailers (A56859)
2025 GPS Trailers...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2014 CATERPILLAR...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
Freighliner Tender Truck (A56438)
Freighliner Tender...
