Plowing feed plots with the BX (no pix)
   / Plowing feed plots with the BX (no pix) #1
Haywire
Central Kentucky
Tractorless :(
Went out to a buddy's place yesterday and put in a couple feed plots for him. I guess between the two plots, it was about 1/3 acre. This was ground that hadn't been turned over in a long time. We both forgot our cameras.. :mad:
I confirmed to myself that the BX just isn't cut out for plowing if the ground is hard and comes up in chunks. The wheel base is so short that it really beats you to death on uneven ground. My neck is stiff this morning from getting jerked around so much.
I lucked out in that the fellow on the neighboring property was discing up his feed plots with a real tractor, so he came over and disced up what I had plowed. Nice fellow.
The other smaller plot had much nicer dirt with no rocks to speak of. Plowing and tilling went much smoother. I did high center on my own furrow once and had to lock the differential to push through. :laughing:
The short wheel base jerking around is also magnified on any implement you have. The gauge wheel I fabbed up on the plow broke fairly early on so I couldn't let it float back there. It either tried to dig in deep or raise up depending on what tractor was doing. That will be better when I get a different stronger wheel and change the setup on the plow a little. After my buddy seeded, I was trying to till the seed in by just skimming the surface with the tiller. That didn't work out well because the uneven ground caused the tiller to also bump up and down, leaving a washboard effect behind me. I suppose I could have lowered the skids but that isn't a quick adjustment and required tools that I didn't have out there. I don't know how shallow it would have gone on the highest setting. It might have been a good solution for that problem.
As a side note, I kind of expected the gauge wheel on the plow to break. I used a lawn mower tire that I literally dug up out of the back yard. I also had it mounted with support on just one side, so the side load twisted it off the little rim it was on. I will have to make a fork for the next sturdier tire so it's supported from both sides.
This whole experience has me wanting a B2920 or B3030 even more, but for the 3% of the time that I would appreciate the B, there's the 97% of the time that it would be too tall and not agile enough for mowing the lawn.
Ian
   / Plowing feed plots with the BX (no pix) #2
I also have a BX 25. Really have no need to deep plow so did not get one. I just bought a small 3 PT 2 gang disc harrow used for $50. It is old (has sealed bearings that are not froze) but has not been used much. No chips in the disc edges from rocks. Have not used it yet. My ground is very rocky so the discs will get plenty of chips. I have some large areas that are overgrown with blackberries and brush. Plan to mow it all down and rake it up with my 5' lanscape rake. Then disc it drag a spike harrow to half way smooth out teh rots then plant pasture grass and then keep it mowed. Will this work. I bought the disc beacuse it was cheap. Will always be able to get my money out of it and maybe a little more.
Any sage advice from you old timers?
Ron
   / Plowing feed plots with the BX (no pix) #3
While I don't put in food plots, I do market garden on a large scale. I started with a BX, but when the business took off, I had to make a switch. The BX gets out of its element quickly when asked to do work it simply was not designed to do. I suspect ground clearance needs gets overlooked by many during the purchasing process. Sometimes, situations just come better into focus and we find our tractor is simply too big or too short or too under powered, etc. Its called experience and the non-static nature of life.
If you have an interest, I chronicled the move from a BX to a B here:
http://www.tractorbynet.com/forums/.../185147-bx1860-vx-b2320-contrast-compare.html
For the record, if I let go of farming on this large of scale, I'd down-size to a BX (new and improved version, of course) in a heart beat.
   / Plowing feed plots with the BX (no pix) #4
Dumb question.
When you say "food plot" does that equal "garden"?
   / Plowing feed plots with the BX (no pix) #5
For everything else, my BX2660 is such a great performing and trouble-free machine that I decided not to buy a larger CUT. It will plow but does drag the front axle and the wheels don't line up properly front to rear. So, for the few times that I plow my and neighbor gardens it will do the trick. Of course, the ground should be in proper condition for plowing to begin with. P.S. I don't get in deep woods with it either.
Dumb question.
He was planting winter wheat for the deer and turkey to nibble on.
Ian
   / Plowing feed plots with the BX (no pix) #7
Ian
Oh, OK, so "food plot" really equals "bait" :laughing:
Consider it a dietary supplement system for augmenting the herd's winter strength. ;)
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2012 SANY SRC 840 4x4x4 40 Ton Rough Terrain Crane (A60460)
2012 SANY SRC 840...
iDrive TDS-2010H...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
