Plumbing tubing question
   / Plumbing tubing question #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
In my previous posts I have gotten advise on my well water quality.. I now want to install a larger whole house water filter, but need to do some re-plumbing to have room for it..
Looking at the current plumbing in my crawl space I am a little confused..
Coming from the well to the pressure tank I have rigid white piping.. From the expansion tank to the current water filter I have a dark red flexible type tubing. From the water filter to the rest of the house I have white Pex tubing..
The fittings from the water filter down line say PEX on the crimps.. I cant find any wording on the red tubing though..
Any thoughts on what it might be?
Brian
   / Plumbing tubing question #2
It is probably PEX. It comes in red,blue and white. Make sure it has the same fittings as the other PEX to be sure. Someone probably just used the red because it was handy. That is why I use white and sleeve it in red or blue. Cuts way down on the scap.
The crimp rings on the white were stamped PEX, but the red crimps rings were not.. The read is also dark red/maroon, not a bright red that I saw at Lowes.
How many other forms are tubing are there? Do they all require 'special' (non interchangeable) fittings?
Brian
   / Plumbing tubing question #4
Be aware that the PEX needs a special crimping tool.:D
It may be wise to draw up a diagram of what you wish to do with the type and size of fittings that are existing and that you will need for the filter. Then if you go to a plumbing supply store the fellow there will be able to help.:)
You are correct... I went back with a flashlight and found the markings of 'Pex 1006' - What does the 1006 mean?
how would it be different than the white pex?
brian
   / Plumbing tubing question #6
As far as I know PEX is standardized but the the different companys won't warranty crossing brands of pipe and fittings. I use different fittings than the brand of pipe because the pipe I use meets my requirements but their fittings don't. I have not had any problems to date. It is only my opinion, but I don't use the rings that are SS and use the side crimp, one tool for several sizes. I had a few break while crimping. Some of the Box stores will rent or loan you a tool so you don't have to buy one for just one job. If you use brass insert fittings be sure to make sure they are red brass / bronze. The yellow brass fititngs have failed in some types of water. In Illinois you have to up size the pipe if you use insert fittings. I have not tried the plastic fittings because they restrict flow even more than the brass. Hope this helps.
   / Plumbing tubing question #7
Not to familiar with Pex but i know that it comes in red and blue for cold and hot, which is code i think when using it in some jurisdictions? Not familiar with codes as my town has ZERO codes for anything, building , electrical, HVAC, plumbing , you name it.
   / Plumbing tubing question #8
Sounds like you have PVC to the pressure tank. It is easy to come off of the pressure tank with PVC. Why not run PVC until you get past the new filter and tie into the existing white PEX and the existing fitting. That would eliminate the need for the special tools and PVC fittings are easy to work with.
MarkV
   / Plumbing tubing question #9
depends on the crimp you use. Ive used the "can crimp with a set of angle cutters" for quite a few fittings with no issues.
as to the OP
white ridgid is PVC
yellow/tan/cream ridgid is CPVC
red/blue/white flexable is PEX
grey flex is polybutylene (precursor to pex and now "band") does not work with standard pex fittings but will work with "tigershark" fittings
black rigid for waste is ABS
   / Plumbing tubing question #10
If you use the rings above, be sure not to put them where you can get back at them. Those are the type that broke on me. I was using the correct tool not pliers.
Service Truck (A59230)
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2018 INTERNATIONAL...
2018 Deere 323E (A53317)
2018 Deere 323E...
1998 PRATT ISO DROP FRAME TRAILER (A59575)
1998 PRATT ISO...
