Pole Barn Project Pics 40x72x14
   / Pole Barn Project Pics 40x72x14
bones1 said:
Looks great!.I like those T5 lights, where did you get them?.
Brad 217-370-7073
Cost is $137.90 each. This price includes shipping. Case of lamps is $120.90. (40 per case)
24 inch wide
6 x 54W T5HO Linear Fluorescent
High Output Instant Start Ballast
***Lamps sold separately
Applications - Warehouses, industrial and retail sites.
Features:
Quality die-formed galvanized steel ballast housing and cover
Highly reflective white die-formed reflectors
120-277V instant start, electronic, universal ballast
Includes two wire-form hangers for mounting
Access cover for 3/4-inch conduit and wire entry
24-inch wide design accommodates NFPA and Factory Mutual codes
UL Listed for damp locations
1-year warranty
Note: Fixtures must be mounted a minimum of 7.5-inches below ceiling
3.3-in H x 24-in W x 48.8-in L
Typical mounting height: 15 to 30 feet
Lamp Output: 2600 lumens
Lamp Color Rendition: 82 CRI
   / Pole Barn Project Pics 40x72x14 #83
I changed all my C-stores to T3s (exterior) and have been trouble free for several years. Cold, rainy nights they just shine shine shine. Worth the $! NICE BARN! M6040 should be delievered next week.
   / Pole Barn Project Pics 40x72x14 #85
Keving, I've been following your post. thanks for posting photo's I've been working on my barn for a year..haha!! Trying to save money. Anyways I like that skirting on the bottom of the outside. My barn will be mostly a horse barn so it will remain clay with bedding. I was worried about the ends of the metal rusting over time as it would be in contact with the clay. If I have this 2ft skirt I can easily replace if necessary. Hopefully it lasts as long as the warranty quotes. I also wish I had not decided to do a second story. It's created a lot of work and killed my friends lifting all those rough cut 2x8's and 2x10's. I've been convinced by long time horse owners not to use concrete in the stalls with rubber mats. Can you post a closeup of how the lower panel is attached to the upper panel? I assume there is some metal coil behind the upper panel that is bent over the lower panel to shed water.
I'll start a seperate thread of progress as it's exciting to see barns go up. I have all posts, girders and floor system for second story done. Next is second story walls/trusses/roof.
Thanks for the post. The transistion from the lower "skirt" to the upper metal is a piece of metal called "Z" channel. This is put on before you put the upper metal on and, when finished, the z channel is behind the upper metal, over the top of the lower metal and about 2 inches down the front of the lower metal. I'll try to get some pics for you this weekend. I look forward to seeing your barn!
   / Pole Barn Project Pics 40x72x14 #87
Kevin, what a great post and a beautiful building. Looks like it's built as strong as a Sherman tank.
   / Pole Barn Project Pics 40x72x14 #88
Keving, If I could ask another question on lighting.How many 6 bulb fixtures do you have up in the picture with the tractor. Did I count four and how big is the lighted section of your building?.I need to light a 30x36 building and was wondering if 4 of these fixtures would give enough light.Thanks.
bones1,
There are 4 of those fixtures lighting a 40x48 area. IMHO, I'd stick with 4 for a 30x36. I like a lot of light. I also wired each light to it's own switch so I can select the proper amount of light needed.
keving
   / Pole Barn Project Pics 40x72x14 #90
Mornin Kevin,
Boy your barn came out just great ! The tractor looks dwarfed inside of that building ! ;) But Im sure you will find away to fill it up. :) Thanks for all the great pics !
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
