Removing PLATE or ears on T posts easily
   / Removing PLATE or ears on T posts easily #11
Thanks to all for some creative answers. Neglected to mention I have ~ 20-30 to do so stopping to make a jig is not feasible as part of the fence is down and I'll have cattle everywhere if I don't hop to. Opted for the vise/chisel/pop off method- still takes some time but they're coming off. Next time for a bigger section I'll remember to find the ones without the wings or to make the suggested tools. Almost thought pounding in upside down was a clever solution until I quickly realized the plates get in the way of the pounder. Anyway, thanks for all the input.
Bob
You _could_ 'redneck' them. Put 'em in upside down leaving the plates on. :)
Harry K
   / Removing PLATE or ears on T posts easily #12
You could buy them from Tractor Supply. I bought 250 last year and over half of them fell off before I got them in the ground. I had to tack weld them back on. They are much needed in this area. The best way to get them off is to lay them at a 90 degree angle over a log. Stand on the t-post and use a air hammer to force the plate off. Good luck.
   / Removing PLATE or ears on T posts easily #13
Use one of these air hammers to strip off the plate.
   / Removing PLATE or ears on T posts easily #14
I've always just used a 2-3lb hammer and just beat them over and off. Occasionally need heavy pliers or vice grips to finish it off.
   / Removing PLATE or ears on T posts easily #15
I've seen earless version at my local farm supply store.
ask around, you can likely order an earless version for a few pennies less than the normal ones.
New Holland 308 Manure Spreader (A59814)
New Holland 308...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Kubota SVL75-2 Track Loader (A56436)
2021 Kubota...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
24220 (A56859)
24220 (A56859)
