Rental Yards here now require 3/4 ton truck or better when towing.
   / Rental Yards here now require 3/4 ton truck or better when towing. #61
I got a heck of a funny look when I bought my international. I drove the wife's honda down the flordia to pick it up and decided it would be easiest to put it on a uhaul trailer and bring it home. I had a heck of a time telling the lady on the phone what my truck was and that it was capable of hauling the honda. What was even funnier was to make things easier I just told her it was a dodge dually. The look on the manager's face at the rental yard was priceless when i rolled in with a 4700 international! I asked him "I am not sure if i can pull that honda or not, what do you think?" :D Needless to say he and i both got a good laugh out of it and I was on my merry way. I dont think the rental yard down the road has a 3/4 ton policy or not, I have never went in there with less than a 1 ton truck? :thumbsup:
   / Rental Yards here now require 3/4 ton truck or better when towing. #62
I guess the rental years around my parts are a lot more laid back. While I do have a 1 ton truck, my old trailer was a 7ton, and they had no problem letting me pick up this load with that combo.
That boom lift is probably about 13k by itself.
   / Rental Yards here now require 3/4 ton truck or better when towing. #63
I agree with everything you mentioned but comparing the weight to the tow vehicle. My f150 can legally tow slightly more than double its weight. It weighs 5600 lbs and rated to tow 11,300 lbs.
Agreed , but trailers with that weight are required to have brakes which makes that a safe combination .... towing a 4200# air compressor with no brakes required with a 3300# truck is a accident waiting to happen.... put that 11k load with no brakes behind a 6k truck and try to stop it.
   / Rental Yards here now require 3/4 ton truck or better when towing. #64
Had that happen when the plug disconnected on an 8k#+ 32' TT, going down a 1 mile hill....By the time I got it stopped, the rotors were glowing and was sitting in a cloud of smoke...I don't want to experience that ever again.
   / Rental Yards here now require 3/4 ton truck or better when towing. #65
No brakes, is that legal? If so point made.
   / Rental Yards here now require 3/4 ton truck or better when towing. #66
I had to check this out, on the Ford website and sure enough it can tow 11,300 lbs, but only if the trailer is equipped (weight distributing) hitch.. If pulling a standard non weight distributing trailer it is 5000 lbs. And a max tongue weight of 500 lbs. I was starting to think there wasn't a compelling reason to have purchased my one ton..
   / Rental Yards here now require 3/4 ton truck or better when towing. #67
All trucks including 2500 series require a weight distribution hitch above a certain limit. Some 3/4 ton trucks have a 300 lb tongue/3000 lb limit without one. The 500/5000 limit is actually average to above average in 3/4 tons.
Unfortunately many don't realize this. I see a lot of skid steers and mini excavators being hauled behind 3/4 ton trucks without a WD hitch and 99% of them are exceeding their hitch limits. You can purchase aftermarket hitches but that doesn't change what the manual states.
Having the WD hitch spreads the tongue load across all the bolts holding the hitch on rather than just the rear bolts taking all the tension. Not to mention adding addition weight to your most important stopping axle, the front.
You are correct, towing capacities between the 3/4 ton and 1/2 ton are similar. What you gain is cargo capacity.
   / Rental Yards here now require 3/4 ton truck or better when towing. #68
   / Rental Yards here now require 3/4 ton truck or better when towing. #69
Exactly.
Chris
   / Rental Yards here now require 3/4 ton truck or better when towing. #70
I'm pretty sure the GM trucks don't.
They do. On the 3/4 & above its 750/7500# before a WD is required.
Chris
   / Rental Yards here now require 3/4 ton truck or better when towing. #71
After a little more digging at least for the- 03 3500 Dodge srw 305 HP Cummins GCWR of 21,000 lbs. and with the class 4 receiver hitch- 10,000 lbs. trailer weight 1000 lbs. of it tongue weight. My manual does state that an equalizing hitch is required on any class 3 or 4 hitch and tongue weight above 350 lbs. Now my question is- are there older 10,000 lb. rated trailers still commonly in use, without weight distribution hitches. If so, it would seem that the One ton trucks and possibly 3/4 tons maybe can haul these older trailers reasonably? safely where a half ton can not?? Or are all 10k trailers (even old ones) built with weight distribution hitches?
   / Rental Yards here now require 3/4 ton truck or better when towing. #72
   / Rental Yards here now require 3/4 ton truck or better when towing. #73
Glad to see the rental yards starting to care.
The one I used to rent from was just the opposite, they'd try to get you to tow their equipment with anything you had just to get a rental. My buddy had a '96 Jeep Cherokee and needed to rent a chipper. The rental yard rented him a good sized Bandit diesel powered chipper and insisted it only weighed 3000lbs. He was dubious based on it's 8-lug wheels but took it anyways. Said it was so heavy he had to keep it around 20-30mph to keep it under control and had to use low-range to get it started on the hills. When he was done we looked up the specs and it was close to 7000lbs, I let him borrow my F-250 to return it.
This same place also insisted it wasn't necessary to chain down a trencher I rented. "Just put the blade and the digging boom down and it'll be fine, we do it all the time" :confused2: I pulled around the block and chained it down.
   / Rental Yards here now require 3/4 ton truck or better when towing. #74
A weight distributing hitch is not part of the trailer it is a special ball mount which has sockets built in for weight distributing spring bars , you then add a set of "snap up brackets" to the A frame of the trailer, the snap ups attach quickly so they could be moved from trailer to trailer if need be , then you add a set of spring bars appropriate for the weight of trailer you're pulling and set the tension when you hook up.
Ray
   / Rental Yards here now require 3/4 ton truck or better when towing. #75
Chris
Maybe the older HD's but not the newer ones. My 2011 has the standard 2.5" receiver hitch that comes standard on 2500 and up GM's. My hitch has a 13,000 pound limit and 1,300 pound tongue weight limit without weight distribution. I know that there was an even higher rated hitch available on some HD trucks.
As an aside I know the 2013 and up Ram HD's are being equipped with receiver hitches capable of 1,700 pounds of tongue weight without weight distribution. I believe that Ram is standardizing on the 2.5" receiver hitches as well as GM. I am pretty sure that a 2.5" receiver hitch is at least available on some F350's but I don't think it's standard. I think the 2.5" receiver hitches are all able to handle at least 1,300 pounds of tongue weight without weight distribution equipment.
The 2.5" hitch came factory with my neighbors 2012 3/4 Suburban.
He makes his living traveling up and down the State towing a 22' box trailer that his tipped the scales over 12,000 pounds.
   / Rental Yards here now require 3/4 ton truck or better when towing. #77
This is only required for skid steers and mini excavators at the rental I go to. Anything else is fair game. Understandably so, even though I run a dodge diesel, it's still a decent load and would be stretching a light duty truck
Same here in our area - 3/4 ton for skids or mini ex's. I had to pull 11K ONCE with a 1/2 ton (it was within the rating by a few 100 pounds - the yard messed up when they gave me the weight of the block) and it was down right scary! Even with 4 wheel trailer brakes it felt like it was pushing the trailer and everything on the truck was working hard on the hills
   / Rental Yards here now require 3/4 ton truck or better when towing. #78
O.K. thanks, I think I got now , my truck just has the class 4 2"receiver hitch so 500/ 5000 no weight distribution, 1000/10000 with weight distribution installed... new trucks with the class 5 and the 2&1/2 receiver are higher... And for the 20 foot 5th wheel utility trailer that I use the most, it's really more a matter of the trailers rating - which is 12,000 lbs. then if I use a heavier duty trailer can go up to about 13500 lbs. = up to the vehicles GCWR of 21000 lbs. 13.5k+7.5k =21klbs.
With those #s in mind it still surprises me that the F 150 can tow within 2k lbs. of my one ton Dodges max ...
   / Rental Yards here now require 3/4 ton truck or better when towing. #79
O.K. thanks, but now This really makes me wonder what gives?? did they up- grade /change since my 03 H.D 3500 was built. -or did they just uprate the trucks
I have had my nephews 2012 2500 Hd Cummins with the new 6 speed manual up on my lift and checked it out verses my 03 3500 nv5600 they both seem to have the same AAM axles, frames as far as I can tell look the same, they both have the same class 4 hitch... Mine is set up for 5th wheel/ his has the goose neck style he will be by tomorrow, is there a major change since the 2012 models and do the changes only apply to the 2013 models
This has been my thinking for a while now. I hear a lot of people on here talking about how much better the newer 1/2 ton trucks are compared to the old ones, how they are nearing the older 3/4 ton trucks of a few years ago. Everyone will agree that many of the older trucks were rated very conservatively, and I have a feeling that manufacturers are now just rating their trucks higher.
I have done my share of work on 1/2 ton as well as 3/4 ton trucks and there is just a huge difference in how much heavier the stuff is built. Admittedly, I don't do a lot of work on newer trucks, so I kind of keep this to myself usually because I can't confirm it. I don't think they are putting dana 60/70/80 full float rear-ends into the 1/2 tons yet, not the much beefier yokes and u-joints that I see in older 3/4 tons. The tranny's might be a little better (not sure), but I don't think the transfer cases are any different. They also still use 5 lug wheels (some 6). Also, do they have the larger radiators, steering boxes (actually I know that many have gone to rack and pinion), power steering oil coolers, larger alternators that came from the factory on many 3/4 tons? Again, I don't know because I don't have a new truck, but find a lot of the hype about how much better the newer 1/2 tons are a little exaggerated. It would be hard to convince me that they are "about as good or better than the old 3/4 ton trucks". More powerful with better trans... yes, but I doubt that they are just as heavy duty- just rated higher.
I am sure I will get flamed for this, and maybe I am way off... so go ahead and educate me, maybe I need it.
   / Rental Yards here now require 3/4 ton truck or better when towing. #80
Wow I went to edit my post and you beat me to it.:eek: I just found the class 5 receiver hitch information and a lot of the 1/2 tons being able to pull these hi weights does seem to be related to this class 5 and weight distributing hitch... I do have to wonder, do the new half tons that are rated for ten k lbs.+ tow ratings utilize full floater rear axles?? that one really matters, come with the trailer brake controller standard, and (E) load rated tires... standard??
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2022 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2022 FREIGHTLINER...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2019 LGMG SS1932E ELECTRIC SCISSOR LIFT (A60429)
2019 LGMG SS1932E...
2013 Ford Edge Limited AWD SUV (A59231)
2013 Ford Edge...
