Ruger Mini 14
   / Ruger Mini 14
Cabelas was actually done on a computer. They had 10-12 of them against a wall for all the gun buyers.
That was about 18 months ago so maybe I am exaggerating. But it was a long time from salesman to cash register.
It seems like going thru the whole process makes you feel like you are doing something wrong.
   / Ruger Mini 14 #32
now that i don't doubt.
gander mountaion is like that. they tripple check.
the salesperson checks. they have another sales person double check..and before they release the gun they get a manager sign off to release.
   / Ruger Mini 14 #33
Dodge man, you really need to try an accustrut for that pencil barrel:
The Original Barrel Strut for Mini-14s
/pine, the Ruger has a chamber that will fire both .223 & 5.56 safely and Ruger has put this in writing.
sld the best part about the wallyworld experience is being escorted out after your fieram purchase.....just in case you decided to go postal with an empty weapon, the manager would wrestle you to the floor and put you in a sleeper hold:laughing:
   / Ruger Mini 14
Oh yeah, I been thru that before. They won't even let you carry the gun out of the store.
   / Ruger Mini 14 #35
really? wow! i guess they's freak out if they knew how many people migth be carrying!
   / Ruger Mini 14 #36
The Mini-14 uses Ruger's scope mount system; the system uses a set of 1/4 moon shape recesses in the receiver; the scope rings attach there. It is a nice system; when I had my Mini-14 25 years ago, I could easily remove and reinstall the scope, with little to no change in zero. It is a nice system. The rifle comes with a set of scope rings.
You can see the little crescent shape for the mounts in the picture here; click on "integral Scope Mounts"
Ruger® Mini-14® Ranch Rifle Autoloading Rifle Features
Serial number starts with 582 which I believe implies that it has a drilled and tapped receiver already for a scope.
   / Ruger Mini 14
Can you use the iron sights underneath the installed scope?
   / Ruger Mini 14 #38
Not with the factory rings. A web search shows there are aftermarket versions though. There also appears to be a see thru Picatinny rail that uses the Mini-14 mounts.
   / Ruger Mini 14
I just got home from wally world with a new Ruger Mini-14 Ranch rifle! It's always a good day when you get a new gun.
Thanks to all for the feedback and experience.
Now a trip to Cabelas for some ammo.......
UNUSED DIGGIT 20'X20' HEAVY DUTY ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
SLIDE MASTER ALUMINUM SLIDES (A54757)
SLIDE MASTER...
Case Titan 3530 (A55218)
Case Titan 3530...
Caterpillar CS-433C Soil Compactor (A55787)
Caterpillar...
