Running Water Lines
   / Running Water Lines #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
I need to run about 350 feet of water line. I plan to use 1.25 inch all the way - PVC that comes in 20 foot sections. I want to put in a couple of those frost-free faucets, but also I want to be able to pump water into my one-acre tank (pond), such that the pump will run 100% of the time during these periods.
I picture just having the open pipe sticking up and a 90 directing the stream to the tank, with a gate valve. Only problem is that it would be subject to freezing, but I don't know of a long neck frost-free setup for such a big faucet.
Any ideas?
Also, I plan to rent a trencher. Would a walk behind be OK, or should I go for the bigger one? In heavy clay, only occasional rocks, none bigger than 3 or 4 inches, going about 24" deep, how long will it take to trench the 350 feet?
   / Running Water Lines #2
If you want to pump to the pond so the pump will run full time during that period, think about a pump relay. It could be set up so when that line runs, it turns the pump on, and keeps it on till that line shuts off. That would minimize cycling on the well pump. That could be tied to the rest of your irrigation too. Most good timers have a Master Valve/Pump relay connection(actual pump relay is a seperate unit).
While you have the trench open, think about electrical, low voltage lighting, and irrigation. It would be the time to get that in while the trench is there...
I have dropped wire in to trenches for irrigation valves, even though it was a way off project. It is easier and cheaper to do it all, then to run the trencher again, risk hiiting the 1-1/2 line you just put in ect.
350' is a long run... Have you done water needs calculations(GPM) to make sure you don't have excessive pressure loss?
I haev trenched that much in clay in 2-3 hours. It is, though, very dependant on your particular conditions... It would be a great opportunity rent a hoe /forums/images/graemlins/grin.gif
My experience has been that when I turn on an inch and a half pipe full blast the pump will run all the time. In the past, going a different direction toward the creek, I found that I could fine tune the valve so that the pressure stays the same - doesn't decrease and run the tank out of air, but also doesn't increase thereby shutting off the pump. The cycling you refer to is the reason for this, along with the need to get some water in my pond that is getting low in this dry weather.
I wouldn't know the first thing about needs calculations. I guess I need whatever I can get. The source is inch and a quarter coming out of my pressure tank, so it wouldn't seem to make sense going bigger than that, or would it?
This phase is not really for an irrigation system, just a faucet so I can hook up a water hose and water the garden which is near the pond. Right now we are dragging about 150 feet of water house out there. The reason for the extra footage is the need to put some other faucets in, plus having to go around my building to avoid the driveway. There will be several corners in the water line.
Putting wiring in the hold makes sense, but the bury cable for those distances might get pretty expensive. Since my wife wants a gazebo in that area, I had better consider that though.
   / Running Water Lines #4
I rented one of these before to dig my 650 foot ditch for high speed cable lines.
http://www.toro.com/professional/sws/loaderattach/trencher/22465.html
It took me only 3-4 hours to do mine. I'd guess less than 3 hours for you.
Have you considered high pressure hose for the water line? 20 foot sections is a lot of places for a leak to develop. Hose would eliminate leaks if it's all 1 roll.
   / Running Water Lines #5
Not sure how it is in Texas, but around here with all the roots and migrating rocks all those joints would be asking for trouble. Better to buy a roll and minimize your chances of leakage.
As for the frost faucets, I've seen them as big as four inch diameter with a six foot riser. You'd probably have better luck searching in the snow belt. Pete
   / Running Water Lines #6
I'm planning to run about 350' feet of line from my pump to the back yard and think Boondox has a point about the joints. I have that black texas clay and have concerns about the expansion and contraction of the soil pulling PVC joints apart over time. I'm kind of leaning towards poly tubing for the long run. I might switch to PVC for the actual lawn sprinkler setup in the yard. But at least I'd have one continuous run from the pond.
   / Running Water Lines #7
I've done something similar, but a little more complicated than what you're proposing. I wanted to keep my pond at a constant level and provide water to a number of faucets throughout my property, such that a 150' hose would reach any spot on 5 acres from one or another of the faucets.
Of course, I don't have to worry about freezing.
I ran a 1-1/2" line from my well to the back side of my pond. It would have been closer to run in to the pond on the "front" side (closer to the well), but eventually the water inlet for the pond will be hidden in natural pond landscaping. That was a total of about 600'. I then tee-d off that line with a 1" line that I ran up the central "spine" of the property for about 300'. I popped up out of the ground with 1" verticals to a 3/4" hose bib every so often.
At the end of the 1-1/2" line to the pond, I placed a Hudson float valve. When the pond water is low, the float is lowered and the water can flow through a 1" outlet. When the water level reaches the float it pushes up and turns off the flow.
I dub the trenches with a rented, walk-beside trencher in sandy= with no rocks. I still have a lot more trrenching to do; more water lines to the other end of my property, electric and propane line trenches. Next time I will rent a ride-on trencher. I made that decision even before I discovered I had heart problems. The walk-beside is OK for short runs. I paid about $80/day for the walk-beside; the ride-on will run about $150/day, but will be faster.
I ran all the trenches and returned the trencher, installed the pipes, then backfilled with the FEL on my little tractor.
Here's a picture of the float valve. It was about $35. It took about 3 days of constant running to get the pond from this level up to near the top of the sandy area on the shore.
   / Running Water Lines #8
Here's a picture of about half the pond so you can compare the volume. Overall, the pond is probably 12' deep. Once the pond is full, it only takes a couple of hours per day to keep it full in the dry season. During the rainy season, like now, the well water is not needed -- the problem is keeping it from overflowing. I can't imagine that yours would seep out any faster than ours in our sandy soil; I can't imagine having to run it all the time after it gets full.
   / Running Water Lines #9
Here is some of the trench I dug; this is near the well; the pond is w-a-a-a-y out and over to the left.
   / Running Water Lines #10
At my place, there is a literal gridwork of underground utilities between the buildings and even to the dock on my lake and the island in the lake. An old college roommate owns an "underground plumbing" service. So, I've sort of had a professional do all of my work. Well, he ran the expensive equipment anyway. I got to do all the dirty work. /forums/images/graemlins/tongue.gif
First off, since I have so much underground, I can tell you that you need to bury a conductive tape along with your pipe so you can later locate it. Otherwise, being a plastic pipe, you will not be able to locate it. I don't know about you, but I'm beginning to be off just a bit on where I think things are that I buried 15 years ago. Just put me on a Ditch Witch and I'll always find a water line. /forums/images/graemlins/blush.gif
Also, I ran a 2 1/2" water line back to my place. From there, the smallest line anywhere to any place is 1". I have frost free faucets sticking up in several places that are 1". Based on that, I'd certainly just advise you to put in a large frost free faucet at your pond. I don't know how deep you have to go in your area, but I started out at 36" deep with the main line, and each successive line afterwards went under that line when crossing.
One quick thought, you may want to see what it will cost for you to have a company come out with a boring machine and just punch the line in for you. I had my college buddy use his boring machine for the last few underground additions. That is really nice! No mess, no rut, and it's simple to just set the run at whatever depth I know to be under all other utilities. Besides, I don't know how I would have added electricity to my island otherwise.
As someone else pointed out, a single solid run is much less likely to break with no joints. The stuff I had run for a water line out to my barn is extremely tough. On a really muddy day I had a concrete truck get hung up right over my water line. He sank down well over 36". As a precaution, I shut off the water to the barn to prevent an even bigger mess when he ruptured the line. As it turns out, he got two of his rear wheels around the line and sawed on it for a while. Even so, it never broke! /forums/images/graemlins/shocked.gif
After that episode, I have used a single roll of line even when not using a boring machine. A small boring machine would do what you need. It may not be too expensive if there is any competition in your area. My buddy does underground bores up to 60" now. Apparently that drill bit is rather expensive. He told me that when they get that bit stuck they dig it up; no matter where it is - under a highway or even under a building.
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
