Stump pushing
/ Stump pushing #11
The hole you had to make for that stump was huge. I don't think a dozer is the right tool for stumping, and either do you since you are bringing in a trackhoe.
That's a beauty though and if you only had a dozen to do than it might be easier than bringing in another machine.
Do the stumps burn black because of the sap?
/ Stump pushing #12
/ Stump pushing
Maybe I should have put something in the hole as a reference. The depth is only about 18" so it's not all that deep in my opinion.
I'll agree that the track hoe is better suited for this. However, I've got the dozer, the time (about 3-10 minutes per stump), and he charges $105 an hour. Plus, I can do some that he would end up damaging good tree limbs to get his machine to.
They burn black from the sap in the heartwood.
Thomas
/ Stump pushing
Thomas
/ Stump pushing #15
Great pictures TxTom. I'm doing the same thing with a Case 450C on 70 acres. It can take me longer than 3 to 10 minutes however on certain really troublesome stumps...but some small ones I can push out directly without even cutting....those I like. It is a neat feeling to see those stumps come out.
I've tried using my back-hoe, but the dozer is faster.
/ Stump pushing #16
/ Stump pushing #17
I couldn't tell which way the 6-7' was measured I thought deep and if that hole was 7 feet deep then we're talking about a crater. If only 18" deep then you did good. Why not do all 60 if it only took 3-10 minutes? That's only 10 hours of work on the long end.
My problem is that the clay gets stuck in the roots and the stump won't burn unless an excavator can flip it around and maybe split it first to remove the dirt.
/ Stump pushing #18
/ Stump pushing #19
Nice photos !!
A dozer is a bit more effective than my 5245 ballasted with a 1 yard dirt bucket, and a chain attached to the top link mount to pull it on the rear wheels and jerk it with the 3pt...
I think my bounce safety valve wont like it either... anyways it works for 2 stumps...
/ Stump pushing #20
Nice photos !!
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2004 Kubota M4900 Utility Special (A60462)
2004 Kubota M4900...
207278 (A52708)
207278 (A52708)
2022 CAN-AM BOMBARDIER LIMITED RTV (A59823)
2022 CAN-AM...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
