Stump pushing
/ Stump pushing #1
TxTom
Huntsville, TX
Just thought I'd show what I've been doing to get these out. The dozer is on the light to medium range (15,000 lbs 70 hp) but my soil is all sandy loam with some clay below.
The first shot is one for reference. I wear a size 12 so this one is about 16" and is at least 2 years old.
/ Stump pushing
/ Stump pushing
First side cut.
/ Stump pushing
All 4 sides cut.
/ Stump pushing
Putting some pressure on the top while lifting and watching to not spin the tracks. You can see it starting to give.
/ Stump pushing
/ Stump pushing
The final product. I didn't have a tape measure but I'd guess it to be about 6-7 feet in total length. The older stumps that have started to dry out will usually burn with black smoke for a couple of days. I've got an estimated 50-75 of these to deal with but I'm going to hire my neighbor with his track hoe to pop the rest.
Thanks for looking
Thomas
/ Stump pushing
Thanks for looking
Thomas
/ Stump pushing #11
The hole you had to make for that stump was huge. I don't think a dozer is the right tool for stumping, and either do you since you are bringing in a trackhoe.
That's a beauty though and if you only had a dozen to do than it might be easier than bringing in another machine.
Do the stumps burn black because of the sap?
/ Stump pushing #12
/ Stump pushing
Maybe I should have put something in the hole as a reference. The depth is only about 18" so it's not all that deep in my opinion.
I'll agree that the track hoe is better suited for this. However, I've got the dozer, the time (about 3-10 minutes per stump), and he charges $105 an hour. Plus, I can do some that he would end up damaging good tree limbs to get his machine to.
They burn black from the sap in the heartwood.
Thomas
/ Stump pushing
Thomas
/ Stump pushing #15
Great pictures TxTom. I'm doing the same thing with a Case 450C on 70 acres. It can take me longer than 3 to 10 minutes however on certain really troublesome stumps...but some small ones I can push out directly without even cutting....those I like. It is a neat feeling to see those stumps come out.
I've tried using my back-hoe, but the dozer is faster.
/ Stump pushing #16
/ Stump pushing #17
I couldn't tell which way the 6-7' was measured I thought deep and if that hole was 7 feet deep then we're talking about a crater. If only 18" deep then you did good. Why not do all 60 if it only took 3-10 minutes? That's only 10 hours of work on the long end.
My problem is that the clay gets stuck in the roots and the stump won't burn unless an excavator can flip it around and maybe split it first to remove the dirt.
/ Stump pushing #18
/ Stump pushing #19
Nice photos !!
A dozer is a bit more effective than my 5245 ballasted with a 1 yard dirt bucket, and a chain attached to the top link mount to pull it on the rear wheels and jerk it with the 3pt...
I think my bounce safety valve wont like it either... anyways it works for 2 stumps...
/ Stump pushing #20
Nice photos !!
2001 Peterbilt (A60352)
2001 Peterbilt...
1991 INGERSOLL RAND DD-24 SMOOTH DBL DRUM ROLLER (A62129)
1991 INGERSOLL...
HEAVYEQUIPMENT TIRES (A60736)
HEAVYEQUIPMENT...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 TROXELL 150...
iDrive TDS-2010H...
2016 Ford E-450 Passenger Bus (A61568)
2016 Ford E-450...
