stump speech
/ stump speech #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
I just ordered a hydraulic cylinder to use yanking stumps. Hopefully I'll be able to chain or strap it to the big ones and pull out the small ones without all the digging. I'm thinking of using some 1 1/2" or 2" black pipe to save on some chain cost, flatten the ends and drill for clevis.. I got a 4" bore x 34" with 1 1/2" rod. Should give me enough (almost 14 tons) to pull 8"-10" stumps, who knows, I'll post pics of the wreckage.
/ stump speech #2
Whatch gonna hook it to that will withstand 14 tons of force?
I sometimes have trouble using the 8000 lb winch on my truck, it'll drag the 10,000 lb truck while the object I'm wanting to winch sits still:p
/ stump speech #4
Are you going to build feet & pull the stump staight up? A pair of tongs to grab the stump and some arrangement to transfer the load to the ground would seem simple enough to build and would address Skyco's question.
/ stump speech
I'm planning to go stump to stump with it. A leg for a fulcrum will help too. Right now I'm wondering if the whole thing is a stupid idea.. but I have lots of smaller ones to pull anyway.
/ stump speech #6
I'm not sure how well the pipe will work for you. I've flatten some in the past and the welded seam likes to split. I have one of those 10 ton hydraulic ram sets that came with a set of chains to make the cylinder pull instead of push.
/ stump speech #7
I made a hydraulic stump puller that more or less lifted the stump rather than pulling it sideways as yours seems to do. Actually, it lifts at a 45 degree angle to plumb with the idea that it would not be trying to break all the roots at once. I just want to say that based on my efforts, 10 tons isn't nearly enough lifting force once a stump gets bigger than a modest size. My particuliar design would cut the side roots as well and still wouldn't budge some 8 inch stumps afterwards. (I hate to put a number on the diameter because stumps taper so fast that it depends on where you measure them) As others have said on this subject, a lot depends on soil conditions and type of tree. I've got heavy clay. Shallow rooted cedars come up nicedly, even the larger ones, but tap rooted trees-not so much. On the plus side however, if the stump is smaller that that critical size, it pops out so fast you don't have time to read the pressure gauge.
Also, if the cost of chain is of concern, consider the cost of hydraulic hose long enough to keep you out of the way.
Good luck.
John
/ stump speech
I sure wish I left my stumps 6' tall. Plenty more to come tho.. Maybe if it won't pull the 10 inchers, it'll put enough stress to them that I can dig with my father's little BX on the other side and get them to go. Anything to not have to deal with the big 2wd on the muddy slope..
/ stump speech #10
It's amazing how tough some stumps are, but they do have to hold up a big tree full of leaves in high winds.
I had some decent luck this weekend pulling trees over by putting the chain around the tree at 6' above ground & driving away. You get pretty good leverage up high like that. Most times the whole stump & root ball come up out of the ground. Occassionally a tree will break off a little above ground level, so I'll have to go back & work on those stumps some more.
Anyway, I'll be watching this thread to see how your puller works out. I'm always watching out for good tree pullin' ideas.
/ stump speech #11
I like the dozer idea but I've had good luck burning out stumps. Drill multiple holes in the stump and top them off with diesel. Repeat a couple times a week for a month or two. When saturated, light it like a big candle, it will burn for a couple of days getting roots down to a foot or two below the surface.
/ stump speech #12
I'll wait for the pictures. I'm not sure I understand how he's going to use this to pull stumps.
I have learned that "fresh" stumps can be easier to pull or dig then older stumps. The roots of fresh ones seem to be more pliable where as older stumps the roots are like rock and hard to break or dig through.
Wedge
/ stump speech
I'm just going to use it like a hydraulic come-along with 14 tons of force. Don't know if it'll work at all. If you see a piston flying over your house ..
/ stump speech #14
14 Tons...about the force of a good log splitter. Maybe.....But, I gotta be shown. :D
If you could pierce under the stump and then use leverage from the hydraulics to pry it out ?? Or....maybe not. I dunno....they are a pistol. :laughing:
/ stump speech #15
Can you do this on fresh stumps? My gut says they probably have to dry out first to suck up the diesel.
gg
/ stump speech
Just ordered some grade 70 1/2" chain to use doubled. That hurt. At least it's made in the USA. It gets me to 22K# working load limit. I wonder how much safety factor they figure in..
/ stump speech #17
Aw heck don't worry about the safety factor, just make sure you are sitting inside an uparmored vehicle when you operate it.
/ stump speech #18
I used my electric winch to do about the same. Works swell.
I think you'll find anything over 6" is going to put up one heck of a fight.
Here's how I tackled mine.
Pic A,B,C, Multiple trunked stump I spent many hrs digging all the way around about 4' deep and cutting many large roots via chain saw.
On the final side/dig, I went extra deep and pushed it in the hole with my tractor while pulling with the winch on the other side to get it to this point.
Pic D, Back filling the under side. Plan was to tip it out on its own root ball.
Pic E, This was useless, as was the same attempt pulling with the tractor. Just no traction.
And nothing in range to tie to as an anchor for the winch. So,,,,,,I built a dead head.
Pic F, Old spare tire with chain and a hole.
Pic G, Old spare tire with chain in the hole.
Pic H, K, Rig it all up. Power comes from a plug off the rear of my truck.
Pic L, Standing straight up again, albeit slightly taller. Getting it to this point took just about all it had.
Pic M, Chain just going slack.
Pic N, Action shot.
Pic O, All done.
/ stump speech #19
Will.....I'm impressed with picture "D"....just after your 790 picked it outta that hole and set it down again. ;) :thumbsup::laughing:
2013 C&M TRAILER CHLORINE DIOXIDE MANIFOLD TRAILER (A67714)
2013 C&M TRAILER...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
2009 FREIGHTLINER M2 Slick Line (A67714)
2009 FREIGHTLINER...
PALLET WITH 3 ELECTRIC CHAIN HOISTS AND ONE MANUAL CHAIN FALL OUTBOARD MERCURY PARTS MOTOR (A66738)
PALLET WITH 3...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
