TC35-45 reverse cooling fan??
   / TC35-45 reverse cooling fan?? #11
I picked up a brochure for this while back, and if I can find it I will post manufacturer info. It basically consist of a thick center hub that encloses a solenoid that shifts the blades to the opposing angle for a few seconds to reverse (airflow) direction. Had applications for many LARGE commercial/industrial applications.
   / TC35-45 reverse cooling fan?? #12
Found the brochure in my deepest darkest brochure archives; It is the "Cleanfix" reversible fans by Novatrax Intl Inc; Cleanfix reversible engine fans. It does not use a solenoid as I thought, but air pressure from onboard sources, or a separate compressor to expand a plate to act against a eccentric to rotate blades, and uses a spring to return blades to normal position.
well, i think he's just gonna have to pay closer attention and jump off every once in a while to clean the vents and watch temp gauge!:D
thanks!
   / TC35-45 reverse cooling fan?? #14
Pusher fans were available in the 70's - used on rigs like skid steers used in cleaning chicken houses.
   / TC35-45 reverse cooling fan?? #15
The Clean fix does both. Normally pulls, but when needed it will push to clean the rad/grill, and then return to the pull position. Look to spend around $3,500 or more.
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
208316 (A58375)
208316 (A58375)
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
Deere 331G (A53317)
Deere 331G (A53317)
