TC35-45 reverse cooling fan??
   / TC35-45 reverse cooling fan?? #11
I picked up a brochure for this while back, and if I can find it I will post manufacturer info. It basically consist of a thick center hub that encloses a solenoid that shifts the blades to the opposing angle for a few seconds to reverse (airflow) direction. Had applications for many LARGE commercial/industrial applications.
   / TC35-45 reverse cooling fan?? #12
Found the brochure in my deepest darkest brochure archives; It is the "Cleanfix" reversible fans by Novatrax Intl Inc; Cleanfix reversible engine fans. It does not use a solenoid as I thought, but air pressure from onboard sources, or a separate compressor to expand a plate to act against a eccentric to rotate blades, and uses a spring to return blades to normal position.
well, i think he's just gonna have to pay closer attention and jump off every once in a while to clean the vents and watch temp gauge!:D
thanks!
   / TC35-45 reverse cooling fan?? #14
Pusher fans were available in the 70's - used on rigs like skid steers used in cleaning chicken houses.
   / TC35-45 reverse cooling fan?? #15
The Clean fix does both. Normally pulls, but when needed it will push to clean the rad/grill, and then return to the pull position. Look to spend around $3,500 or more.
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
