This day in 1997, of my house build
   / This day in 1997, of my house build
19970505 Monday
Took day off work
Roughed in most of basement under slab DWV.
Finished sheathing on exterior rim joists.
Install tyvek house wrap on right end of house and front.
Don installed my tub faucets. Think that was his last day helping get plumbing started.
Some pics taken later, but they fit in here.
Basement overhead DWV. Did not get any pictures of under slab piping.
Upstairs back to back baths. One regret was not using ball valves for shut offs. I didn’t know better then, used what I was used to. First time I needed to shut water off to the shower valve, these shutoff valves leaked like crazy. Had to cut hole in drywall, cut them out, and put in ball valves.
Master soaking tub.
   / This day in 1997, of my house build #333
19970505 Monday
Took day off work
Master soaking tub.
Is there an access panel for those valves? Jon
Yes, but to replace them I needed a bigger opening. Still haven’t taped the drywall from that job.
   / This day in 1997, of my house build #335
Does the tub get used, or when was the last time anybody used it? I read that they are used 3 times by most people. I've taken out quite a few for clients that want big walk in showers and never used their jetted tub a single time.
It gets used occasionally.
19970506 Monday
After work.
Installed exterior door on west side of house ( now door to garage).
Finished under slab DWV.
19970508 Thursday
After work
Installed 5 front porch 3046 windows.
19970509 Friday
Underslab DWV failed inspection. I think I had a pipe entering another from above and they wanted it on the side.
After work, built 5x4 deck at side door.
19970510 Saturday
Hutch helped 3 hrs
Tyvek on back of 1st floor.
Install rafters on bay window.
Felt on front left porch roof.
LOT: (7) Wheel Loader Shanks (A59076)
LOT: (7) Wheel...
HYD POWER CHAINSAW & WRENCH (A52708)
HYD POWER CHAINSAW...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
