Tractor towing 101 - how to load and secure?
   / Tractor towing 101 - how to load and secure? #21
THat sucks. Glad I live in the rural midwest state of Ohio
+2. Glad I live in Texas. And East Texas, at that. If you're using ANY tie-down method out on our county roads, you are probably in the minority, ha! :D
   / Tractor towing 101 - how to load and secure? #22
I wuz gonna say that JasG's recommendation is not required, but then I read the rest of it. Truth is it is not required, but if you live in a state run by government loving types (sorry about the politics..) then you will probably get hosed at some point. That is sad, IMHO.
I secure mine with 4 chains. 2 connected to the grill guard, which is very sturdy. 2 connected to a shackle in the drawbar (2 independent chains). I use ratchet binders and I have never had the tractor move a mm. I probably do not have much tractor moving in my future, but I will continue in this vein, and will fight any charges I might get tha contradict logic (though I doubt I would get any here)
   / Tractor towing 101 - how to load and secure? #23
Reviving this older thread while looking for info for my next trip
Go to the massey ferguson vintage classic forum and go to page 2 Look for massey 65 field find by porkchopsmnn. Go to page three of this thread post #28 and read from there. This will be give good and bad examples how to haul a tractor. Be Safe.
namyessam
Definitely don't do that at home!
I drive on until my ball sinks about 4" which is 800 on the tongue. Chain front frame to trailer d rings in an "x", back tractor up until 5/16" 70 chains are tight, hook 2 more to rear d rings / drawbar support, and ratchet bind rear. 2 more 1/4 gr 43 from toplink boss to stake pocket, lever bind, duct tape binder handles. Pull up 800lb load bars on trailer and it's good.
I have no easy access to a scale until I get on the road for a ways.
What I've been doing is calculating the tongue weight w/ a scale some boards and pipes as shown on
at etrailer. But I'm thinking of substituting triangular pieces of wood for the pipes.
This is about what I plan on doing, plus straps over the FEL.
Question:
Does anyone use wheel chocks for the equipment ON the trailer?
   / Tractor towing 101 - how to load and secure? #24
I tie down 4 points to the main frame or axle of the tractor with chains and binders, then each attachment gets its own tie downs [usually just pull straps but by Michigan law it needs to be done]. Once the LEO see the chains and tie downs I don't get a second look. I hold a CDL so they don't go as easy on us as a normal stop would be. As far as tong weight, the more the better. So it depends on the vehicle I am pulling with. The f150 usually gets between 600 and 1k and the F250 up to 2k depending on what I am pulling. So the load gets loaded however I need to to get the proper tong weight. So no rules just whatever is needed to make a safe haul. CJ
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
