welders welders welders
   / welders welders welders #41
Jim if you decide to buy an inverter SMAW machine. I have my brother-n-law's Everlast PowerArc 200ST. This welder is very impressive with 6010. I'm starting to believe it will stack 6010 better than my Lincoln V350-Pro. And right there with any of my Lincoln SA-200s.
Mark with Everlast takes very good care of us here!:thumbsup:
POWERARC 200ST - Stick Welders | Everlast Generators
The Everlast 200 is quite a bit bigger than the Maxstar/ESAB sized machines which are really small and convenient for portable work.
   / welders welders welders #42
Jim,
I had a couple of the 125 Hobart's and it sounds like something is not right with yours only going 4 inches before overheating. Maybe the fan is not working or air passage blocked?? The Hobart 125 machines I had woudl have run those plates without stopping.
   / welders welders welders #43
I've never run a Maxstar or ESAB welder. I use to have a Linde VI-206 Mig welder. I understand ESAB bought them out.
I played with the PA-200 ST with my LN-25 wire feeder.
   / welders welders welders #44
Jim 4 minutes would be bothersome. Maybe it was due to extension cord? Insufficient generator? If you don't supply it with sufficient power, the volts go down and the amperage goes up and I suppose that can cause problems.
I'm thinking that too!
My Hobart 140 would have no problem welding in those 8x8 plates.
   / welders welders welders #45
I was 20' off the main panel on a 12ga cord. I agree, there very well might be something wrong with mine and I should get in touch with someone about having it checked out.
I never had any issues with my MM130XP, and regret ever selling that thing.
As for getting an inverter stick machine - probably not going to happen any time soon. Too many bills, and too many other tools ahead of it on the list.
   / welders welders welders #46
You can always turn it down, but you can't turn it up any farther than it'll go.
Seems like the money part is where folks get hung up. Good welders aren't cheap. Even the cheap welders aren't all that cheap when you start getting into ones that will weld serious thickness'.
Lincoln TIG 300 300 | eBay
Some great deals on the heavy - and heavy duty used I thought I got a bargain on my Tig 300 300- but somebody scored big here on a much newer one. As long as they don't have to pay to ship it far.
   / welders welders welders #47
but hokayyyyy..... Furu methinks you take forum opinions a little too seriously. You only have to follow my orders if nothing better comes up. :laughing: But nothing will. This will spiral off-topic before anything definitive comes up. It always does because duty-cycle is like chainsaw size, pickup size. Any size you can imagine on the internet - size is king!
These welds, all you can see in this pic, 167 inches were done continuously in 25 minutes on a 20% machine, (on generator) continuous welding not shutting down once. It's a LOT more, and higher heat than those 8x8" 1/16" thick plates. BTW 1/16" thick has a known amperage requirement that is significantly below the Hobart 125's capabilities. You might consider othee deficiencies, that 125 is a good machine. I had a Hobart 115 (or 120?) for a few years in the '90s (pre-internet).
I was wiped out though.:shocked: It would take a foreman cracking a whip to get me to do that again.
....no foremans here i'm pretty much unemployable at this point :D
Sounds like someone is taking things a bit personal for no reason.
This is why I avoid this sub group of TBN. Personalities are really really overly sensitive.
   / welders welders welders #48
I got a Maxtron 450 and a feeder that I can't remember which one it was (it was a nice one), once for $25. I had to drive an hour to go get it and I should've bought the other 3! They were in the attic space of a big light pole fab plant and listed on CL by the maintenance guy trying to regain the space. Relics from before they upgraded the time before the current equipment. Covered in dust and AS-IS. So I gambled thinking the feeder would be good or easily fixed, and it turned out I was right - plugged in and worked perfect. After checking it out at home on my power supply I took it to my LWS and made a quick $300. :D Then I sold the Maxtron to a kid for $50 untested. Never did hear back if it worked or not. I didn't know if the Maxtron would work on single phase like the Invisions will, and didn't care enough to rewire it to find out.
   / welders welders welders #49
I have to agree with bath sides, will my small machine weld longer than the DC? Yes. Is it good for the welder? No. If all you are going to do is weld little repairs than the small machine is fine but even small projects will be have to be put on hold many times if you really don't go over the DC. So there are three groups.
1. People who weld very small things and don't go over a 20% DC.
2. People who weld medium sized things and over the DC and don't care.
3. People who weld medium to large things and care about their welders and won't go over their DC.
If you are in the first or second group the small welders are fine but if you are in the 3rd group you NEED a larger welder with a bigger DC. I for one have been doing medium sized things and have had to wait for the DC. I have some larger jobs I want to do and the 20% DC will not be enough. Ed
   / welders welders welders #50
X2......
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
200722 (A51247)
200722 (A51247)
CASE CX330 EXCAVATOR (A52707)
CASE CX330...
2121 (A51244)
2121 (A51244)
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
