Well pump with breaker AND fuse?
   / Well pump with breaker AND fuse? #31
I talked to an electrician at a birthday party today. He said the box with fuses is not part of code at all. The disconnect switch is, the fuses are not. He said it could be hard wired in that box and it would be fine.
   / Well pump with breaker AND fuse? #32
Fuses are very much part of code in all the jurisdictions I have worked. The second coment you make makes no sense. Hard wired simply means no cord and attached via conduit, armored flex etc. Fuses are still used when exact amperage requirements are needed. With 3 phase its a setup that uses "heaters" as the means to control motor current or via a frequency drive. In any case, fuses can be made to exacting tolerances with quick or slow acting protection, breakers are a close approximation. I would argue his comment but then, maybe your jurisdiction is not the same.
You could always use those quick low fuses to protect your Jub tweeters.
Sorry all, inside joke.
duggo aka filmboydoug
Uh oh....the neighborhood just went to he((.... ;)
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
2016 FREIGHTLINER  CASCADIA TADC (A59575)
2016 FREIGHTLINER...
John Deere Welcome Saw Sign (Green) (A57454)
John Deere Welcome...
