What did you do to your tractor today?
   / What did you do to your tractor today?
Sad story.
I had such cases with the customers while working in a position of workshop manager. It happens when engine sucks in water inside the cylinder. But usually engine even not starts after that.
In your case I would better fix an original engine or would purchase remanufactured one from certified workshop with the warranty. It's more expensive, but with minimum risk.
Try to get back to a seller and talk to him.
Had the motor about nine months but not to worry I can use the rods out of the old one with new rings and shells so it'll be a good motor when done:)
   / What did you do to your tractor today? #142
Yeah, rod looks awfully... Hope you'll successfully fix an engine.
   / What did you do to your tractor today? #143
I installed the hydraulic valve under the deck plate of my B7800, plumbing to follow..........
   / What did you do to your tractor today? #145
If you dont mind me askin....what's it for ?:)
I plan on using it for the 3rd function for my grapple. Your left foot does not do much so I am putting it to use. Right hand-loader control, Right foot-HST,
Left hand-steering wheel spinner, Left foot-grapple.
   / What did you do to your tractor today? #146
I helped my Uncle, almost got stuck while trying to dig some ditches for him to divert some water for a garden spot. The ground hasn't seen a machine in 20 years or more, the whole area is like a swamp. The worst part was busting a hydraulic hose on the FEL trying to get out. Luckily my cousin has a hydraulic and machine shop. LOL, next door to Kubota. It worked out good and we were up and running in about and hour.
   / What did you do to your tractor today? #147
Saturday I was up at Lunenburg; used the tractor to run the cultivator over my three food plots. I swapped out the cultivator for the bush hog and serviced it. Then ran it to cut a trail along Lyle Creek for 300 yards before the foliage (and snakes) come back! Ran like a champ!
   / What did you do to your tractor today? #148
all I can say is......
WOW you are lucky the chinese didnt find that tractor
   / What did you do to your tractor today? #149
Hooked up the disc and went over the garden. Much better this year then last year. Probably cause last year was record snow and this year was almost no snow.
   / What did you do to your tractor today? #150
Hooked up the planter and planted 12 ac corn. Doing the same friday and Saturday
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
2017 Mitsubishi Outlander Sport SUV (A55758)
2017 Mitsubishi...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
Wright Sentar (A50120)
2018 Bobcat T190 Compact Track Loader (A55302)
2018 Bobcat T190...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
