Where to buy unusual size U-bolt?
   / Where to buy unusual size U-bolt? #1
schweizer
Southern Oregon
Kioti DK45SE Hst
Probably an easy answer? I'm just looking for a 3" wide U-bolt for attaching stuff to my ROPS. (Kioti DK45) Up until now I've used hose clamps to attach fire extinguisher and lights, but I'd like to build a sun shade out of fiberglass and plywood, and attach it with U-bolts. Reasonable? Local hardware stores don't have 3" wide. Any online outlets that you use? Thanks.
Marcus
   / Where to buy unusual size U-bolt? #2
Get some all tread and one inch flat bar and make your own.. I do it all the time.. Lou
   / Where to buy unusual size U-bolt? #3
Yes. ... Be sure to grind off the threads in the area of the bend. Otherwise you risk cracking in the stress riser at the root of each thread.
larry
   / Where to buy unusual size U-bolt? #4
Marcus
I get them from Agri-supply Agri Supply - Search
Instead of using plywood for your canopy you might consider something like 'divinycell'...it is a closed cell PVC foam that when laminated/encapsulated with fiberglass it is as strong as plywood and weighs about 95% less...I'm currently fabricating one myself...
Good ideas. Thank you!
   / Where to buy unusual size U-bolt? #6
McMaster-Carr is always a good place to look for hardware.
   / Where to buy unusual size U-bolt? #7
any leaf spring shop should have several sizes on hand.
   / Where to buy unusual size U-bolt? #8
A real good spring shop or 4x4 shop can make their own. But I agree with Lou, get some all thread and make your own.
   / Where to buy unusual size U-bolt? #9
Boat Trailers use a lot of them.
   / Where to buy unusual size U-bolt? #11
My 1999 F250 Super Duty 4x4 uses 3" wide leaf springs/ubolts - just got new ones for the rear springs a couple of months ago. The rear bolts have the rounded U and the front springs use the squared U - take your pick and order appropriately.
   / Where to buy unusual size U-bolt? #12
If you want it to look better get some rod and and thread the ends and bend or you could use bolts and a piece of flat steel say 1 1/2 in wide and put two holes in it.
   / Where to buy unusual size U-bolt? #13
Three inch is a common size and should be widely available. Try the already mentioned places or a spring shop will likely have them made and on hand. If you make it as far as a spring shop don't be concerned. Most any I have ever seen look like a throwback to the middle 1800's.
   / Where to buy unusual size U-bolt? #14
You could check an auto parts store. 3" is a common exhaust pipe size.
   / Where to buy unusual size U-bolt? #15
I've got them before for a pipe top trailer from a muffler shop.
hugs, Brandi
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61306)
2008 Ford F-250...
Honda utv cart (A56859)
Honda utv cart...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
