Where to weld bucket hooks?
   / Where to weld bucket hooks? #91
I did not put these shackles on my bucket I bought the tractor used.
But these are the handiest things to have , I can not tell you how many times I have used them in the past year. I know this much if I ever get another tractor with a FEL the first thing I will do is get some welded on my bucket
   / Where to weld bucket hooks? #92
Thanks to this forum topic it has helped me successfully add a few hooks to the JD. I plan to add a 2" trailer set-up on the center of the bucket very soon.
I had two 40+ foot pine trees fall last winter and needed a way to move the 6-8 cut sections.
See the results in the posted pics. I painted them JD green.
   / Where to weld bucket hooks? #93
I know I lose alot of my loaders lift capacity with this setup, but definitely no need for a hood guard :D
Another use of receiver tube on top center of bucket, i have yet to need or want weld on hooks.
JB.
Nice. I didn't see it but is that length of angle that sits on the bottom lip of the bucket pinned or connected in any way, or does it just sit there. I realize the pole is a rigid piece of 2x2 tube steel but personally if I was building something like this for myself I would put two pinsor bolts through the angle and bucket to lock it all down tight with zero chance of it coming loose.
   / Where to weld bucket hooks? #94
Here is my idea for how to install them!
But with the forks below i find i never use the hooks on the bucket! My first time with forks....best attachment I've ever purchased!
   / Where to weld bucket hooks? #95
Looks good. I put a slip hook in between the two grab hooks. I can then run the chain through the slip and over to a grab hook on one side or the other to take up the slack. The slip hook is nice when you need to hook to a rope or cable eye, strap, etc.
2021 KUBOTA SVL75-2 SKID STEER (A60429)
2021 KUBOTA...
2005 Cheverolet 2500 Pick Up Truck (A59814)
2005 Cheverolet...
2017 John Deere 6120E (A53317)
2017 John Deere...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
2006 GMC C5500 BUCKET TRUCK (A59905)
2006 GMC C5500...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
