PlumCrazy814
Bronze Member
For clearing trees, best to use a chain saw and when you have cut down what you want down, go rent a stump grinder for a few days.
I had my previous CUT for 15 years, beat the carp out of it, and never had it to the dealer. I did have to break it down to replace a coupling for the front drive, though. I think the part cost $20. The advantage of having a dealer close is being able to gets parts easily and quickly if you need them. Hopefully they will still be in business when you need that part.
I wouldn't count on a FEL on a small tractor for breaking ground, if that's what you have in mind.
As other's have stated, if you intend to stomp through the woods go for high clearance.
The JD2305 has a design flaw with where the transaxle oil filter and hydro cooling fan are located. If you go that route and intend to drive it through the woods, install a skid plate on the rear.
