Which truck would you get?
   / Which truck would you get? #81
Good luck working on the CFO...that's the toughest job of all! :)
Best of luck on whatever you decide. Take it easy and stay safe out there!
   / Which truck would you get? #82
Well been chattin the CFO and she's givving me the evil eye about another truck, for now :laughing:, will have to see. I also contacted the guy on Tundra Solutions about the header upgrade. I really hate the idea of trying to sell my truck then being without, then looking for another, so I guess I will stay with this one for now.
I do appreciate all the honest opinions given here. That was what I needed to hear.
As for the brakes, there is sooooo little aftermarket support for this truck it's not funny. That's why I did the Dodge flip up tow mirrors on mine. The ones offered to fit over Tundra mirrors are an absolute joke. I love mine now. Full power in both positions and heated as well. The fold flat against the door just like factory ones, and as I found out the other day, they fold forward some without damage, thankfully.
What kind of headers are you talking about, shorties, or longtubes? If they are shorties keep your money. I would get a tow tune for the truck.
   / Which truck would you get? #83
Tuners don't really work well on newer Toyota vehicles... And you are right about the shorties, only the long tubes make a difference. I think his only two options are Pacesetters and JBA.
The headers I am looking into are long tube versions. Those and swapping belt drive fan to elec, and dual exhaust, one one tester showed a real 34 hp and 34ft lb torque increase at the rear wheels. He had before and after dyno sheet to prove it. Also got a 3-4 mpg increase. Pretty sweet deal.
   / Which truck would you get? #85
I doubt there will be any noticeable MPG increase.
   / Which truck would you get? #86
I went from 4.6 Ford with hd springs to a Dodge with 5.7 and standard suspension. They are both 1/2 ton trucks. I pull a 6000lb trailer. The new setup is night and day better. I think the right 1/2 ton gasser will work fine for you, but It needs plenty of motor and brakes as well as the right rear end.
   / Which truck would you get? #87
Don't forget, upgrading the power will do nothing for the brakes, which was another concern of yours (and would be mine as well). I may have missed it, but what type of brake controller do you have? If you don't have a Tekonsha Prodigy, get one! I had one in my prior two trucks (before I got one with the integrated brake controller) and it is awesome! It also has a boost feature which forces the trailer brakes to come on before it senses an inertia change. I love it except for city driving, which I rarely did. When towing, the correct (and properly adjusted) brake controller will make all the difference in the world.
   / Which truck would you get? #88
One thought I would add to this. I have had to panic/evasive stop with my old tractor on a trailer behind my 3/4 ton. Little Civic cut me off bad on the highway. I was only pulling about 5500lbs that day. It was a hand full even with the light load and the 3/4 ton diesel.
My 5th wheel is a little shorter, but a couple thousand pounds heavier than the OP's. I would not want to try a panic/evasive stop with 1/2 ton irregardless of the new ones having bigger brakes etc. Nor would I want to get in to high cross winds.
Yea if I so end up swapping trucks, it will be a 3/4T no matter what engine. I seriously considered a new 3/4 ton when I was looking for my replacement '06, but I wanted a particular engine (6.0L with the auto shut down of 4 cyl on hwy) but it wasn't offered. And if I remember correctly, the trannies were less sofisticated a well.
I guess the factories have wisened up a little over the years.
As for panic stopping with my rig, it's more like stopping faster. I really have to stand on the brakes in a situation like that.
   / Which truck would you get? #90
I was on H-50 in Sacramento when that Civic cut me off. Glad I was on a straightaway and not curves. Antilocks on the truck were anti-locking. That is about the only time I was glad to be going the Calif 55mph towing limit to begin with...
Been cut off a couple times on H-101 up near Petaluma on the way to Bodega Bay with the 5th wheel, but nothing like the incident on H-50.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2007 Chevrolet WA4500 Box Truck (A50323)
2007 Chevrolet...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2015 Ford F-150...
Skid steer auger plate (A50322)
Skid steer auger...
