Woods Stump Grinder
   / Woods Stump Grinder #1
OrangeGuy
SW of Minneapolis, MN
2008 Kubota L4240 HSTC
I have been researching what might be the best stump grinder for my Kubota L3430 tractor. I looked at the Dougherty Turbo Saw but am concerned about only cutting the stumps off at ground level and being limited to 10" and smaller stumps. I am now interested in the Woods TSG50 Stump Grinder (check this link Woods Equipment Company - 15-50 PTO HP Stump Grinder - Model TSG50
Does anyone have any experience with product? Does anyone have general knowledge about 3pt stump grinders that could give an opinion on this product? I can get one for $3450 FOB local dealer. It looks like it could be a good match for my tractor.
All insights will be appreciated.
OrangeGuy
   / Woods Stump Grinder #2
Don't know much about them. A friend has one on a bigger new holland that does pretty well. Needed new teeth at that. How many stumps do you have and what kind of bids to get them removed. He had a bid of 350 to do his stumps ( a bargain) but got the stump grinder in a package deal (a good deal in it self). Not the easiest job but doable.
   / Woods Stump Grinder #4
i have a tsg50 for my bx24. used it today as a matter of fact. i must have done 100 stumps. what a piece of equiptment it is. its rock solid built. in the year i have owned it i have done maybe 250 stumps 3"-20" with an average right around the 6-8" range. i always take them about 6" below the surface and after all that it has barely worn the paint off the teeth on the wheel. it comes with a 20" sandvik wheel btw. my bx only has 17 pto hp and it still rips right through them so your tractor would be more than enough. personally i think the 3pt grinders are the way to go. if i was side by side with a big vermeer or something like that, it might end up grinding the stump slightly faster but by the time you moved that machine over to the next one i would be half done stump #2 already. only thing i can say is it gets a bit bouncy when cutting but someone i know that has used the big machines says it does the same thing. i guess thats somewhat normal. doesn't really affect anything. i wont come with the hydraulics done, obviously but i think woods has an optional kit. i just ordered everything i needed from sirplus center and did it all myself.
   / Woods Stump Grinder #5
i have a tsg50 for my bx24. .... i wont come with the hydraulics done, obviously but i think woods has an optional kit. i just ordered everything i needed from sirplus center and did it all myself.
What for example is needed in the way of hydraulics? do you have a list of what you got from burdens surplus?
thanks tim
   / Woods Stump Grinder #6
bota jim ........... consider me first in line to buy it when you are done with your stumps. :)
   / Woods Stump Grinder #7
hey i dont have an actual list of what i ordered. i didn't keep that info. i can tell you i got a prince 2 spool valve assy with the power beyond sleeve. elbow fittings for the cylinders, all the hoses and reducing bushing. basically all the plumbing. also needed a few quick disconnects. instead of mounting the valve assy to my tractor as a rear remote i welded a mounting plate to the frame of the grinder and mounted the valve to it which puts it just under chest height with it dropped down on the ground for use. i just did the hyd as part of the grinder rather than the tractor. here is a good pic of it in action. this particular stump, at ground level, was about 24". i took it from 8" above ground to 4" below in under 5 minutes with only a bx24 for power.
   / Woods Stump Grinder #8
Do you know what the Stump Grinder - Model TSG50 sells for?
   / Woods Stump Grinder #9
i relly dont know. most stump grinders are quite expensive. most around $5g so i assume its around there somewhere. i got this one brand new from a dealer that didn't sell it on ebay and i think he was going under so he unloaded it for, according to him, less than what his cost was. i managed to pick it up for $2400.
WATER TRAILER (A58214)
2023 CATERPILLAR 259D3 SKID STEER (A60429)
2023 CATERPILLAR...
2020 CATERPILLAR 303.5E2CR EXCAVATOR (A60429)
2020 CATERPILLAR...
43055 (A55851)
43055 (A55851)
2019 CATERPILLAR 420F2 IT BACKHOE (A60429)
2019 CATERPILLAR...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
