New Holland 3930-1 4.50 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the New Holland 3930-1.
25-50 HP Tractors
About the New Holland 3930-1
New Holland 3930-1 Discussions (68)
Here are the most recent 3930-1 topics from our community.
  1. L
    Determining New Holland 3930 hydraulic fluid level
    This is my first post here, so hopefully it will help. I recently bent the hydraulic fluid dipstick tube on our 1994 - 3930 - 2wd. In my discussions with the repair person we use for our...
  2. 4
    NH 3930 - Need a wiring harness
    I am searching for a replacement wiring harness for a 1994 New Holland 3930. NH no longer sells them apparently. Does anyone have a source for one? If so please provide contact info. Thanks in...
  3. A
    Changing fuel filter on NH 3930
    I need to change the fuel filter on my 3930 but have never done it for fear that I may get air in the system and not be able to get it started back up. I have a few questions. What procedure...
  4. J
    NH 3930 Steering Issue
    I’m new to the forum and new to owning a tractor. I’ll apologize ahead of time for any lack of knowledge. Started the tractor the other day and now it takes a tremendous amount of force to turn...
  5. K
    1997 NH 3930 - No Start
    Ran fine when parked about 5-6 months ago after Dad tilled his Garden. Visited property with him about 5 weeks ago (right before he passed), tried to start to no avail. Came back a week ago with...
  6. C
    New Holland 3930 rear wheel rim
    Any recommendations to find replacement rear wheel rims for a New Holland 3930? Need a quantity of 2.
  7. G
    Ford/NH 3930 hydraulic help needed. (newbie)
    I just got the tractor in the title, and it's got a 7209 loader on it. I just replaced the 4 hoses coming off the control box as they were all leaking. I took care to change them one at a time and...
  8. G
  9. PM Wells
    Front Loader Brackets Ford NH 3930
    A few years back I had a Ford NH 3930 that I wanted to install a front loader, It was a Bush-Hog brand loader The loader I had come off a Ford 3910 or similar model, and the brackets would not fit...
  10. nwut05
    97 New Holland 3930 Leveling Box Question
    Hello again. My question is can i convert my current style leveling box which is almost froze up and change it to a style with crank handle. The only ones i can find say they fit a 3910 and not a...
  11. nwut05
    New Holland 3930 Hydraulic help
    Ok Guys Gals and anyone who has information that can help. I just purchased a new to me 1997 3930 with 7310 front end loader. The loader is plumed to the rear hydro outlets. I have a problem with...
  12. S
    New Holland 3930 hydraulic selector valve
    My tractor is about a 96. It has the hydo selector valve under the seat. It switches from rear lift to the front end loader. It jumps out of position for the loader. I use bungee cord to hold it...
  13. P
    New Holland 3930 flywheel won't turn
    My 1990's New Holland 3930 won't start. For background, this is a weird 3930 where a prior owner replaced the deisel engine with a gas engine. Anyway, it has a new battery and power is getting...
  14. Semper Paratus
    New Holland 3930 Won't even crank
    Well yesterday's effort with the 3930 was clipping several hundred feet of right of way and the 50' wide loop road around the house sight (something like 700' in diameter. All told about 3 hours...
  15. Semper Paratus
    New Holland 3930 Hydraullic Upgrades
    My 3930 has a Quickie 310 loader hanging on the front. The source for the FEL hydraulics is a long hose from one of my rear remotes. I have the second 12 GPM hydraulic pump on the left rear of the...
  16. T
    $650 to flush and replace hydraulic fluid on New Holland 3930? Worth it?
    Hello, How is everyone doing? It has been long since I posted here, you know, the hurricane happened and then in laws etc. We sent the New Holland 3930 to the local New Holland/Kubota dealer...
  17. A
    "?? About engine problems with new holland 3930's
    I was talking to this guy who works on and restores tractors and I mentioned to him that I have a new holland 3930. He asked me what year it was and I told him it was a 1999 model with about 800...
  18. A
  19. S
    New Holland 3930 Clutch (photos)
    Not sure this photos will show up. They are photos of my old clutch and a new one I ordered. The new one part number is on the box. The old clutch had the inner tension springs or whatever you...
  20. S
    New Holland 3930 clutch-pressure plate change
    In process of changing clutch-pressure plate. Found new pressure plate and clutch on EBay. Like to ask some of you mechanics if you replace pilot bearing and throwout bearing if they are still...
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the New Holland 3930-1 Subcompact Tractor
5
50 %
4
50 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
woodjo
3930-1 New Holland
Good Solid Tractor
Model Year: 1999
I have had no issues with this tractor. I use it as a loader tractor and general use around the farm. It works well with the Bushhog and is stable on hilly ground. It's a good solid tractor for the money. No issues at my dealer getting parts, they always have in stock any part I need.
Pros: Good, solid tractor.
Cons: Loud engine noise.
4.00 star(s)
professor
3930-1 New Holland
New Holland 3930
Model Year: 1998
Good tractor however parts seem to be hard to find.
Pros: Tough.
Cons: Parts availability.
New Holland 3930-1 Owner Pages
View owner pages to see photos, customization and comments about member-owner New Holland 3930-1s
New Holland 3930-1 Community Rankings
#394 user rating of 2355 25-50 HP Tractors items
#619 Viewed of 2355 25-50 HP Tractors items
#110 discussed of 2355 25-50 HP Tractors items
#999 user rating of 19625 items overall
#1790 Viewed of 19625 items overall
#210 discussed of 19625 items overall
#14 Ranking of Most-OwnerPages in 19625 items overall
