Ford 841_2 4.70 star(s) (3)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ford 841_2.
Vintage Tractors
About the Ford 841_2
Ford 841_2 Discussions (22)
Here are the most recent 841_2 topics from our community.
  1. T
    In need of a Ford 841 Air Cleaner assembly
    I am looking for a complete air cleaner assembly for a Ford 841.
  2. S
    Ford 841 New Clutch Won't Disengage
    I ordered a new clutch and pressure plate for my 841 on ebay. As soon as I hooked up the linkage, I could tell the pedal was low and the clutch didn't seem to disengage the whole way. Adjusting...
  3. S
    Ford 841 Power Steering Valve Nut Adjustment
    New Holland (841) - 4 CYL AG TRACTOR ALL PURPOSE (1/58-12/64) Parts Diagrams Does anyone know the procedure for tightening #43 "Bearing Lock Nut"? My manual says to "tighten it until firm, then...
  4. G
    Ford 841 will not keep running?
    I have I think a Ford 841. It is a row crop, approx. 1958 with a 4 speed 4 cylinder gas engine and power steering. It will barely run for about 20 sec. I have checked all the regular things plugs...
  5. R
    New Ford 841 - couple of questons
    I recently purchased a nice old Ford 841 with power steering at a great price. I'll need to replace the rear rims and tires ($$$). I'll also convert it to 12v with a Pertronix ignition. The...
  6. L
    Ford 841 Powermaster Stalling
    Hey guys! I have searched and searched and am kind of stuck. I have a working Ford 841 Powermaster that someone GAVE me. Pretty awesome stuff! So the tractor runs great when stationary. However...
  7. M
    Ford 841 pricing?
    I'm looking at a 1960 unknown engine (as of right now) 841 with FEL and rear weights. The ad says 12 volt, so I guess it's a diesel. Tires also good from pics, and they say it "runs excellent."...
  8. 5
    58 ford 841 spindle bushing
    Has anybody replaced the bushings at home?
  9. C
    Ford 841
    Hi to all, as a new member to this forum, I'll attempt my first post. My interest is the Ford 841 series tractor. I'll be searching the various posts for info that pertains to these tractors...
  10. S
    59 Ford 841 died, won't start
    This one is pretty much original, with an added front-end loader. It's been converted to 12V, but I'm pretty sure the starter is the original 6V unit, which seems like a fairly common practice...
  11. P
    Power Steering Pump Ford 841
    I am in need of an assembly tool for my Ford hollow cylinder power steering pump (c3nn3a691b 800 Psi) . Part #n310776. This was used in the 50's or early 60's. The other option is a replacement...
  12. S
    Ford 841 Carburator Problem!!!
    I have been fighting with this for longer than I'd like to admit. I have a nice 841 with PS and a Sherman over/under. BUT, the tractor is almost unusable because you never know when the carburetor...
  13. P
    Oil & Fuel Problem: Oil spitting out of.... on my Ford 841
    I am not sure what part this is (can't find it in the Owners Manual) but I have oil spitting out - while idling or in motion. never had this problem and would appreciate help in determining what...
  14. D
    Ford 841 Carb Help Needed
    I've ordered a parts kit from a dealer, but need step by step instructions for rebuilding the carb on my 1959 Ford 841. Any help will be greatly appreciated! -Dennis 7
  15. M
    '58 Ford 841 Powermaster question?
    Looking at a '58 Ford 841 Powermaster tractor. The transmission is stamped with 841-S above the serial number. I was hoping you all could help me with two questions: 1. I've read that the -S...
  16. T
    Can you upgrade a Ford 841 3 point to lift more
    Ok, this is my first post. I have been unable to find any info on the web about how much my Ford 841 will lift at the 3pt hitch. I would really like to know what is the pump flow rate and...
  17. M
    ford 841
    my ford starts good but when you drive 20 ft it stalls out checked voltage reg ok . Fuel bulb ok . I think its timming or carb . What else? Thinking of a new Zenith . What do you think?
  18. K
    Ford 841 runs great for 45 min
    my 1958 Ford 841 starts and runs great for about 45 min then acts like it's running on 2 cylinders or something. At the first of the season I had to replace the water pump but prior to that had no...
  19. M
    Ford 841
    I have a 1958 841 gas and cant see any marks to set the timing on the fly wheel where are they located ? I have a loader connected to the fly wheel might this be the problem?
  20. M
    ford 841 electronic ignition
    I have the kit to switch from points to electronic ignition,I also have to change the coil .Has anyone had any experience doing this? Its a 6 volt positive ground system.Would like to know if its...
[ad placeholder]
User Reviews (3)
Read what TractorByNet members think about the Ford 841_2 Subcompact Tractor
5
67 %
4
33 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
oleone1
841_2 Ford
Ford 841
Model Year: 0
Good value, powerful small tractor with strong loader and easy to work on.
Pros: Good power.
Cons: No live PTO.
5.00 star(s)
Anonymous Poster
841_2 Ford
841-S Industrial
Model Year: 1959
Tractor has an industrial front end and a full size loader bucket, Sherman hi-lo auxiliary transmission. Replaced all the gauges, thermostat and dealt with minor issues such as rebuilding carb, welding a few cracked sheet metal pieces, PS pump, major tune-up, new battery. Starts like a dream with the 6 volt battery tender hooked up, even at 5 below. Use Amsoil 10-30 synthetic oil, starter does not labor as much as my friend's 841 does with dinosaur oil. Working on painting the tin now. There is one major issue. The oil seal on the Sherman transmission input shaft leaks. I have to split the tractor and remove the Sherman hi-lo to replace a $5.85 oil seal. I was amazed the local New Holland dealer had the seal, transmission-engine housing gasket and transmission cover gasket all in stock. A testament to the number of tractors made and still in normal operation.
Pros: Parts still avaialble by the bucket load.
Cons: No heater!
Photo Uploads:
5.00 star(s)
1959ford841d
841_2 Ford
Ford 841D
Model Year: 1958
I have three (2 diesel, 1 gas).
Pros: Nice old tractors.
Cons: Nice old tractors.
[ad placeholder]
Ford 841_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ford 841_2s
Ford 841_2 Community Rankings
#36 user rating of 679 Vintage Tractors items
#50 Viewed of 679 Vintage Tractors items
#25 discussed of 679 Vintage Tractors items
#787 user rating of 19625 items overall
#785 Viewed of 19625 items overall
#543 discussed of 19625 items overall
